  • Guests: 63
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Need Help building a simple SSTC
benproiii
Sun Feb 28 2010, 06:12PM Print
benproiii Registered Member #2703 Joined: Sun Feb 28 2010, 06:02PM
i was wondering if i could run this sstc off the 120VAC rectified mains to get more power. Or would the mosfet overheat or something.
i know i would need to use a transformer on the IC's
(this i my first sstc)
(here is the schematic)
ScotchTapeLord
Sun Feb 28 2010, 06:46PM
I believe the issue here is that this tesla coil is being run from what seems comparable to a flyback transformer driver. If it works perfectly at the ~35VDC supply in the schematic, you may want to try raising the voltage, but not all the way to full mains voltage, since this topology (at least, in LOPT/flyback use) is prone to very large voltage spikes.
If you have an oscilloscope or have access to one, you could upgrade it the way Steve did himself, into Class E. Otherwise, if you want more power, you should change topologies.
benproiii
Tue Mar 02 2010, 08:33PM
i decided to use the circuit for the sstc Link2
i was wondering if i could use IRFP250N's and not the 260N's.
Mates
Tue Mar 02 2010, 09:15PM
The scheme you posted is single switch classE tesla coil. The problem why you cannot use more than 50-60V is in volatge spikes which are always a problem of classE topologies (voltage spikes can reach more then 3times the the supply voltage). Also, the transformer works as a kind of current limiter which would otherwise have to be replaced by choke or limiting capacitor. On the other hand you can have a look at my high power classE topology which runs on unsmoothed 220V AC Link2
Cheers Mates
