  • Guests: 68
relays
Sun Feb 28 2010, 01:06PM
What about putting a capacitor in parallel to the switch? I think that should work to kill the arc.
Sun Feb 28 2010, 01:10PM
Yes, but sometimes the capacitor needs to be so big to kill the arc, that it welds the contacts together the next time you close the switch.
radiotech
Sun Feb 28 2010, 04:30PM
100 ohms in series with 0.05 ufd makes a good contact snubber. Resistor prevents contact weld. The use of "freewheeling" diodes across relay coils makes them release slowly by retarding flux build-down. This may be an issue with contact arcing.
