  • Guests: 60
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
DRSSTC problems
mmt
Thu Feb 25 2010, 05:45PM Print
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
Hi,
I'am testing my medium sized drsstc with steve's OCD driver and full bridge of hgtg30n60's.
But it works kinda strange, i was regulating input voltage and viewing size of sparks, and on over 100VAC sparks stopped grow, OCD works fine I think, ocd led wasnt flashing, and on higher voltage an arc sometimes jumps from seconadary to primary. But coil is tuned fine. Anyone has this strange problem before?
ScotchTapeLord
Thu Feb 25 2010, 06:06PM
I am no expert but I think your sparks may be detuning your coil. The sparks add extra capacitance and eventually lower the Fres enough to affect tuning. Are you using primary feedback? If so, try lowering your primary resonant frequency.
I think it was EastVoltResearch who explained tuning once... If I remember correctly, he said it will break out at higher power all at once when tuned properly. It makes sense, since it will be out of tune until there is substantial streamer loading.
So try tuning slightly lower... After getting someone else's advice. :)
mmt
Thu Feb 25 2010, 06:56PM
yea primary feedback, of course i have try to tune it, by putting bigger cap to primary, but sparks just gets smaller even at higher voltages.. and more often sparks arcs to primary from sec.
ScotchTapeLord
Fri Feb 26 2010, 03:33AM
I would think you need only a small change in tuning, so I would think you'd be better off with more primary inductance rather than capacitance... Or perhaps lowering the secondary with respect to the primary?
raff
Fri Feb 26 2010, 05:56AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
Martin,
maybe that can help..
mine did also some sec-pri flashes when I went for primary feedback, with secondary base feedback, everything was ok even with 220Vac input...
Goodchild
Sat Feb 27 2010, 03:26AM
ScotchTapeLord wrote ...
You need to tune it low so that when you crank up the power the sparks pull the coil into tune.
mmt
Sat Feb 27 2010, 04:13PM
My MMC is 190nF in tune for small voltages, and then i added 9,5nF, sparks was shorter on small and higher voltages... so this didn't helped.. no matter i try to tune, sparks never gets bigger over 100VAC on bridge.. sad
Sat Feb 27 2010, 05:51PM
Yes, it sounds like detuning.
To properly tune the DRSSTC for maximum arc output, you really needed to monitor primary current vs. input voltage.
Basically, you'll want to detune your DRSSTC at low power levels. This will be evident when it takes a LOT more current at lower voltage to generate the same length sparks as if it was tuned for lower power.
So in a nutshell, your coil is really detuned initially, and it requires the capacitance of the longer streamers to bring it back into tune.
The best way to go about this is to measure primary current vs. input voltage to hit a set strike target. Move the strike target away in say small increments taking this data. Then repeat for various tuning points. Stack all the data and you'll be able to see trends on detuning /retuning, etc...
