  • Guests: 44
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
What is better for DRSSTC: full-bridge or double half bridge?
BSVi
Tue Feb 23 2010, 07:27AM Print
BSVi Registered Member #1637 Joined: Sat Aug 16 2008, 04:47AM
I'm going to redesign my DRSSTC (Link2 and I'm in doubt whitch is better for DRSSTC - full-bridge or half-bridge with two paralleled IGBTs.
Half-bridge with paralleled devices gives double curent, and full-bridge halfes rise time.
In Terry's pdf "Steve's vs. Terry's coils..." he says that rise time is critical.
So what is better?
Luca
Tue Feb 23 2010, 08:46AM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
I don't think that paralleling IGBTs is a good idea... Conduction mechanisms in IGBTs are a mix of MOS and bipolar mechanism (actually they are bipolar devices), and it is well known that it is not a good idea to parallel bipolar devices (BJT), unless you put resistors to equally divide the current in the devices.
I'm not totally shure but I think that this applies also to IGBT.
Regards,
Luca
mmt
Tue Feb 23 2010, 10:12AM
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
i have never see a paralled igbt's..
Tue Feb 23 2010, 10:22AM
Full bridge is better!
BSVi
There are several IGBTs especially designed for parallelling. They have slightly positive temperature coefficients and well matched.
Luca
Tue Feb 23 2010, 11:45AM
BSVi wrote ...
I see...
In any case, I would choose full-bridge because losses on resistive paths (windings, cables, ESR of capacitors...) increase with current^2...
Regards,
Luca
BSVi
Tue Feb 23 2010, 03:42PM
Would you please explain why?
GeordieBoy
Tue Feb 23 2010, 03:52PM
...because you develope twice the peak-to-peak voltage across the load with a full-bridge than you do with a a half-bridge.
Losses can also be spread evenly between 4 switches in a full-bridge which reduces temperatures and improves reliability.
-Richie,
Tue Feb 23 2010, 04:48PM
Full bridge requires less capacitance across the dc bus for the same ripple/hummmm.
The caps are not cheap.
BSVi
Tue Feb 23 2010, 06:04PM
Yeap, but you can double voltage with double current halfbridge too - all you have to do is increase "on" time on your interrupter.
Anouther way to double voltage is to decrease capacitance and increase inductance.
As from my point of view all difference beetwen dullbrigde and double halfbridge is ringup slope (which is doubled in FB design) and maximum current (which is doubled in HB design).
