  • Guests: 18
Mycologist (34)
Some_Polak (31)
brandon3055 (31)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Fusors on Hackaday..
Sat Feb 20 2010, 09:44AM Print
Hi all.
Just noticed this on Hackaday.
Interestingly this effect can be demonstrated without particularly high vacuum by using helium to extend the ion free path distance.
Also it seems like it may be possible to use some clever tricks including the use of glow mode to clean up the chamber according to this page
has anyone else here managed to get one of these beasties to work?
regards, -A
rp181
Sat Feb 20 2010, 04:50PM
If you look in the pics thread, Fabio was able to do the same, but without actual fusion.
Sat Feb 20 2010, 04:56PM
cool :) do you know his email address?
would appreciate some tips.
regards, A
plazmatron
Sat Feb 20 2010, 05:51PM
Just for the crack a couple of days ago, I built a spherical cage cathode, and put it in one of my linear discharge tubes.
Even in such a tube, gas ions will become trapped inside the cathode and form a "poissor" albeit slightly distorted.
Apparently anode geometry is not as critical as cathode.
The vacuum is easily attainable with even a modest pump, however, for doing actual fusion one would need to pump out the chamber with a diffusion pump, than backfill with Deuterium.
Les
