  • Guests: 64
Oscilloscope Troubleshoot Help
Corey
Thu Feb 18 2010, 10:03PM Print
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
Got a 2235 Tektronix Ocilloscope off Ebay. Wondering if anybody that has repair background and would like to know an estimate of how much to fix, or how to fix the trace drawing problem it has. Traces were at .1sec/dev for larger pics, more detailed pics were at .5sec/div. No signal in just ground channel.
Pics:
Th 16341260678 ORIG
Th 16341260688 ORIG
Th 16341260694 ORIG
Th 16341260699 ORIG
radiotech
Thu Feb 18 2010, 11:15PM
If is a bright as photo indicates ,stop! Does the brightness and focus work properly? You can easily ruin phosphors.
Give details of onset history, and if you can reduce trace to a focussed line at faster sweep rates with no vertical deflection. Is there a Z axis input/jumper/switch on the back?
Hazmatt_(The Underdog)
Thu Feb 18 2010, 11:40PM
I think you're stuck in xy mode
Corey
Fri Feb 19 2010, 12:19AM
Yea there is a z-input on the back. If i turn the timebase sweep all the way up and put the volt/div really high like 5v I get descent looking lines, and if i put the volt/div really low I get some really nasty distortion on the vertical axis. If i slow slow the sweep down it's apparent the there is major distortion on the x and y axis.
Pic:
Sweep Mode V/div all the way up-Sweep is at .1sec/div
Th 1266538387
Th 1266538385
X-Y Mode Volts/div all the way up on both channels
Th 1266538383
5v/div ch1 and 2 X-Y Mode
Th 1266538381
