  • Guests: 84
<OT> Screamers
Sun Feb 14 2010, 10:07AM Print
Hi all.
As it appears that the TSA/etc has decided to install backscatter X-ray units at airports/etc (and will soon be putting them on lamp posts/supermarkets/etc if you believe the UK papers, I am concerned about my radiation exposure.
So maybe there is a way to inform people of the risk- the "Screamer"
Build a small device (ideally wristwatch sized) that when exposed to radiation loudly informs everyone around of this fact.
"Caution- Ionising Radiation detected." in a Hawking-esque voice would probably work.
Would also have a use in the unlikely event of an accidental radiation release or another Chernobyl.
Then there's that rather large nuke plant built ON a fault line in Japan... (!)
-A
#include "Backsplatter.h"
Sun Feb 14 2010, 10:40AM
That's a neat idea!
I'll be traveling by air in a few months, I can't quite imagine what kind of radiation detector a Mr Sulaiman Abdullah could carry around without causing confusion.
Probably better I don't bother.
Chris Russell
Mon Feb 15 2010, 05:44PM
Chris Russell ... not Russel!
Conundrum wrote ...
Hi all.
A backscatter x-ray scan subjects a person to about 5 microrems of radiation. Consider that a person will naturally get 275 microrems per day at sea level. 25 millirems annually is considered a safe level of exposure from a single source, a limit which would not be reached unless a person received more than 13 scans per day, 365 days per year. So, it should be understood that unless these really are placed just about everywhere and used on people without consent, the radiation danger is minimal. I suppose that's where the watch comes in.
As for the watch, a 1N4007 will produce a small current in the presence of x-rays. Shouldn't be too hard to detect this current and trigger an alarm. Might be a challenge to string together enough of them to detect the relatively small amount of radiation, however. I also doubt anyone will let you borrow a backscatter machine to verify that your detector is working.
ragnar
Mon Feb 15 2010, 07:56PM
Sulaiman wrote ...
I can't quite imagine what kind of radiation detector a Mr Sulaiman Abdullah could carry around without causing confusion. Probably better I don't bother.
LOL, could be worse, Sulaiman -- I have a friend with the same name as a 9/11 bomber!
wrote ...
Don't walk into an airport with anything that resembles loose wires or veroboard; that's mostly what they tell staff to watch out for. Green double-sided PCBs, a silk-screened panel and you should be fine! wink
Chris Russell
Mon Feb 15 2010, 10:11PM
Blackplasma wrote ...
Don't walk into an airport with anything that resembles loose wires or veroboard, that's mostly what they tell staff to watch for. Green double-sided PCBs, a silk-screened panel and you should be fine! wink
A good point. If it's going to be a verbal warning, I'd also advise against it literally saying "run away." Something along the lines of "danger, ionizing radiation detected" should suffice.
Tue Feb 16 2010, 10:06AM
Why not get some lead foil, cut out letters that read "Kiss It Mr. Security Guy" and stick them to your *censored by the TSA*
Nicko
Tue Feb 16 2010, 10:51AM
YMMV. Depends on the airport. Some are hopeless. At the airport of a major city of a neutral country in Europe, my wife had a professional chef's filleting knife in her handbag (she had just bought it - the town is famous for its knives) - she told the guy on the scanner about it so they could put it in the hold, and he just waved her through.
Tue Feb 16 2010, 11:17AM
I agree... I recently had to fly to Norway carrying a bunch of prototype circuit boards. I couldn't decide whether to put them in my hand luggage or the hold baggage. In the end I put them in a cardboard box in my hand luggage, and put the box on the X-ray along with my laptop for inspection.
Nobody cared. I think as regards electronics in your baggage, just don't pack anything that looks like a Hollywood b0mb! But if you needed some Internet guy to tell you that, you were probably a burden on society anyway wink
I've heard of people having trouble with kit that contained large capacitors. The X-ray may not be able to see through them, and they could be full of explosives, drugs, anything. People have been busted for smuggling drugs inside capacitors!
Tue Feb 16 2010, 01:02PM
hmm.. interesting.
Wonder how many 4HV'ers are on one or more watch lists through no fault of their own?
maybe we should start a protest group...
Chris Russell wrote ...
heh. You know those HV diodes are just a bunch of smaller diodes in series... :)
I'd expect the best ones to be obtained from old defunct triplers etc. Hook up to suitable amplifier, negatively bias them at a suitable voltage and voila.
I also wondered about using a visible detector and a long persistence phosphor such as ZnS with an infrared LED to "damp" remanent luminescence. This would be pretty accurate if combined with a thin pyrolytic graphite "sense plate" (as it can be sanded/cut down to sub mm thickness)
then there's the hacked mouse sensor idea...
As for testing it, I'd use a vacuum chamber (just scored a £20 bell jar and glass plate) and some Sellotape on a DC motor. Instant X-rays from 0.5 to 25 KeV with very little vacuum.
-A
#include "I_HATE_Head_Gaskets.h"
ragnar
Tue Feb 16 2010, 09:48PM
I'm firmly convinced that today's invasive airport security is out of control. As a result I'm really soured by stories of "I got my chefs' knives through security", or "I could have hidden drugs in my crutches and nobody checked!".
Nicko wrote ...
Some are hopeless [...] my wife had a professional chef's filleting knife in her handbag [...] and he just waved her through.
"Hopeless"? Nicko, do you mean you would prefer to be held up, a scene to be made, and attempt to argue through special provisions? I think in this situation you were blessed not to have an immature or a power-tripping guard.
Which is it? I thought we were tired of airport security being invasive and rude? Or do we want them to throw up a fuss and be anal and "not hopeless"? I ask, because if the process were any less "hopeless" than now, I guarantee you won't like it at all.
