  • Guests: 45
where to salvage IGBTs?
dmg
Sun Feb 14 2010, 01:39AM Print
does anyone know or have experience on where or what appliances or comertailly available items, might house IGBTs?
(rating doesn't matter, im looking for sources)
if you know where to find them, or what appliance they can be tore out of, please share it.
doctor electrons
Sun Feb 14 2010, 03:10AM
As far as i know the only place to farm igbts is from industrial vfds (variable frequency drives). Other than that, most
commercial or industrial grade induction heaters will have them in there. Mosfets are readily available in car stereo amps.
However, i dont really know an easy source if igbts. If you find out something good, let me know!
dmg
Sun Feb 14 2010, 03:39AM
forgive me for sounding like a dumbass, but by induction heaters, do you mean an induction (cooking) stove? or the coils that used to heat up metal via induction?
Sun Feb 14 2010, 03:55AM
gatedbreakdown wrote ...
They are both the same, both use coils and induce a current in metal stuff.
I have never seen an IGBT in anything. You can find plenty of mosfets in CRT monitors, sometimes in TVs, and in any LCD, plasma, or LED TV or monitor i am sure they have mosfets for the SMPS. You can sometimes get mosfets from computer PSUs, but at least for older used ones, you will normally find one or two ~10 amp BJTs. Amps of the PWM type have mosfets which has already been suggested. Linear amps contain medium sized BJTs. Any appliance that could have a SMPS could have mosfets.
I have not seen an IGBT, but i have to really work to get the TV's i have gotten.
Zeus
Sun Feb 14 2010, 07:10AM
Zeus Registered Member #2316 Joined: Tue Aug 25 2009, 03:04AM
I have got 4 20N60s from a plasma tv psu.
[Edit: A 20N60 cost $2 US from Mouser. I don't buy stuff online so plasma tv psu's are a good source]
dmg
Sun Feb 14 2010, 07:49AM
hmm.. interesting, never know plasma TVs had IGBTs
how about IGBTs worthy of DRSSTC duty? (200-600A range pulsed)
Sun Feb 14 2010, 08:20AM
The most obvious source of them would be an induction stove (although the chance of finding one of those up for salvaging isn't too great)
I can't think of many other things, large UPS supplies will have them, but most of the smaller home grade ones use normal mosfets (still quite powerful mosfets!)
If you can expand to car electronics, most modern ignition systems use IGBTs, although they are usually encased in a solid block of resin so it is not trivial to get at them.
Sun Feb 14 2010, 10:02AM
I have access to a number of plasma TV PSUs, anyone have a use?
kept them "just in case"...
regards, -A
brtaman
Sun Feb 14 2010, 12:37PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
A good source that hasn't been mentioned are welding machines, they will usually have quite heavy duty IGBT's in them, larger ones nice bricks or SOT-227 IGBTs. Though finding a broken welder with working IGBT's is imo like finding the pot of gold at the end of the rainbow. Just a heads up though.
doctor electrons
Sun Feb 14 2010, 03:01PM
Sorry for the late reply! Both will have them. Also, welders have pretty good ones in them, he is correct with that!
