  • Guests: 56
R/C Drone of Doom
Sat Feb 13 2010, 07:24AM Print
Hi all.
I recently purchased a lightly used (has minor damage but functional) NiMH powered 3 foot Spitfire R/C aircraft.
Also acquired at the same time an R/C heli capable of lifting up to 200g of payload.
The basic plan is to mod the 'plane first as controlling one of these is slightly easier than a heli.
I've been told that the best approach is to motor up to a few hundred feet then cut the motor drive to just above stall speed for a powered glide.
any tips?
-A
"Bother" said Pooh, as he read "Instant Headcrabs, just add water" on his noodle packet..
Sat Feb 13 2010, 08:21AM
If you are asking how to learn to fly these things, the general wisdom of the local model flying club is, that you must come to the club.
An experienced pilot will handle take off, so that you can practice flying, stall and recovery, etc. in a safe altitude, and he will help you to bring the model down in a safe manner.
A glider pilot myself, I can warrant, it is easy to fly, a bit harder to start. Landing is the hard part of every flight, model or not. To loose altitude, a flying aeroplane has to move forward, so in order to land it close to where you stand, you have to fly the right landing approach. It is a complicated procedure. Few planes are crashed in the air, it is when they touch ground it becomes critical.
Cheers, Finn Hammer
Now a paraglider pilot with a limp. frown
Sat Feb 13 2010, 10:13AM
Yes, RC planes and helicopters are difficult to fly. Helis particularly, I remember watching a friend trying to get his new heli off the ground for the first time, next thing it was in pieces with rotor blades zinging past our ears.
But the cheap planes are made of very light, tough plastic foam and can take a lot of crashes without breaking. They also fly quite slow, so they're a good way to learn. They don't cope well with strong winds, though. You can only fly on relatively calm days.
One advantage of joining a model flying club is that they have insurance. If you're not in a club, it's best to fly somewhere quiet, to minimize the odds of hitting a bystander.
Finn, did you crash your paraglider? My boss is hang-gliding in Lanzarote right now.
Sun Feb 14 2010, 05:19PM
Steve McConner wrote ...
Yes, sort of. Can`t really crash a rag. However "I" crashed into a ridge with 60km/h. sprained right ankle. Took more than 3 months to recover, and still some time to go before fully recovered.
Lucky bastard on Lanzarote.
Cheers
