  • Guests: 41
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Recording High energy discharges
rp181
Sun Feb 07 2010, 02:05AM Print
Hello,
I have posted a thread before, but I still have no insight on this. On every single high energy discharge I have done, starting with the 5.6kJ bank, I have gotten a purple frame. I have seen it on other peoples videos, with varying magnitudes.
4336470500 D7ce737a73
I think EM pulse can be ruled out, as this was recorded over 15 feet away. This is also interesting as the middle seems to be where the projectile hits the rails, yet there is a very much opaque garolite enclosure.
Any insight?
Sun Feb 07 2010, 03:03AM
Does the camera show a flash where none is visible to the eye?
If you can see the flash then there are several possible explanations for the apparently purple extension:
1) In color CCD and CMOS cameras, the blue detectors generally have a spurious response to near-infrared wavelengths. Red-hot sources like outdoor gas heaters, or electric toaster elements, appear purple to the camera; the IR emitter of a television remote control appears to glow light blue (try it!)
2) possible blooming of an overexposed image area on the detector array. But that usually runs in columns or rows.
3) Light from an overexposed area landing elsewhere after scattering or spurious reflections in the lens.
Sun Feb 07 2010, 03:05AM
Registered Member #2372 Joined:
well, your camera is definitely being saturated where the bright spot is. Put some dark filters in front of it and take a shot to see if it is just the camera saturation or something else.
Hon1nbo
Sun Feb 07 2010, 03:08AM
the dynamic range of your camera is too small - it will overexpose for the most part, but the blues on cameras tend to be more sensitive than others, and sometimes less sensitive - in the less sensitive case it could explain why only that color didn't blow out, look up your camera and find the spectrum response graphs and see what you can find
-Jimmy
rp181
Sun Feb 07 2010, 05:23AM
I am doubting it is response issues, as on one occasion I got this clearly defined picture:
(5.6kJ, ETG)
100 1947
and the frame after:
Etg3 3
tesla500
Sun Feb 07 2010, 06:23AM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
rp181 wrote ...
(5.6kJ, ETG)
100 1947
Etg3 3
This blue or purple may be explained if your camera has CMOS sensor. When exposure of one frame is completed, the data is stored as analog voltages in tiny capacitors in each pixel. The next frame is exposed at the same time as the voltages on the capacitors are being read out and converted to digital values. During this time, the circuits around the caps are slightly sensitive to light. Extremely bright light can change the voltage read from the caps, causing apparent brighter areas in a frame right before an extremely bright frame.
David
Sun Feb 07 2010, 09:15AM
tesla500 wrote ...
Interesting explanation, and I think quite plausible.
To explore that, rp could record a video close-up of, say, a xenon flashlamp firing. Get several flashes, which would peak at various phases of the video frame cycle, and see if there's a pattern of light "aliasing" onto the previous frame. If the camera or lamp is moving, so the apparent position changes with each frame, you can discriminate the "aliasing" from a flash pulse that actually straddles two frame periods.
Back to my original suggestion: if this is a railgun or electrothermal gun, the plume could have a luminous spectrum very different from "ordinary" light sources, and fool the camera's color filters which are supposed to match human visual response. Link2
Bjørn
Sun Feb 07 2010, 11:43AM
If you post pictures larger than 400 pixels you need to use the width=400 tag to avoid oversize pictures in your post.
Digital cameras will often show bright IR light as purple, try to filter out the IR with an external filter and see if it reduces the purple. Also try the opposite, use an IR pass filter and see if only the purple is left.
Sun Feb 07 2010, 12:27PM
You can see the aliasing effect, or at least one like it, in this video still of a Tesla coil. Notice the lines of little dots coming from the spark gap electrodes.
30incher
There's a similar effect in this Youtube video: Link2
MinorityCarrier
Sun Feb 07 2010, 07:07PM
For NTSC interlaced video, you can extract the "odd" and "even" frames from the original interlaced frame (if you have a good video editing program) and you may find what you want.
