  • Guests: 47
SGTC questions
!Search
Fri Feb 05 2010, 08:02PM Print
!Search Registered Member #2673 Joined: Wed Feb 03 2010, 07:14PM
Hi! First post here :)
I have a project, to build a tesla coil. And SGTC seems to be the most appropriate to begin with. But then also a few question has come up.
The secondary coil is all done in its calculations. But when I was to begin with the caps, I read somewhere that the LTR (Larger Than Resonant) should be 1.5 higher.. What do they mean with that? And also I heard that voltage rating of the caps should be twice of the voltage output. Should they?
And I've noticed that I can connect the caps/spark gap diffrently, but that isn't any big diffrent between these two. But should you have a safty gap if I already have a spark gap in parallell with the transformer?
Hope you can cope my englsih.. It isn't my main ;)
Hazmatt_(The Underdog)
Fri Feb 05 2010, 08:53PM
Try searching the forum.
You'll be surprised what you get if you put a little more effort into it.
