  • Guests: 30
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
HV Peaking Capacitor Question
PanosB_GR
Tue Feb 02 2010, 01:28PM Print
PanosB_GR Registered Member #1680 Joined: Fri Sept 05 2008, 04:19PM
Hello everyone.
I have built a Marx Gen (50kV/stage, 8stages) that suffers from high series inductance. Current, something about 10kA, has a fairly slow risetime, in the order of 100's of nanoseconds. Could a series peaking capacitor increase the current risetime to, let's say, a 100nsec?
What values of capacitance do you reckon would be needed?
Best Regards all :)
--Edit--
Errr, in case anyone is interested:
I drive the Marx to a saturated CuSO4 solution load, that i figured it has something like 15Ohm, 1μΗ impedance. I get the current measurement with a current transformer on the ground return path. The inductance of the Marx bank seems like it's 7-8μΗ, bad enough for high current outputs :P
Tue Feb 02 2010, 06:58PM
You can put a spark gap (e.g. 2x 1" spheres at 2" gap) in series with the output so that the marx will 'errect' itself before output current flows.
Maybe if the spark gaps cannot 'see' each other they don't benefit from uv ionisation so trigger slowly/sequentially?
Tue Feb 02 2010, 07:54PM
The role of the peaking capacitor is to improve transfer efficiency by making a better match between Marx Zout and the impedance of the spark gap. You will have to calculate it from all your variables, and then proceed by trial and error.
jpsmith123
Wed Feb 03 2010, 12:31AM
It's hard for me to believe that you could have that much inductance. My guess would be that you've got spark gap issues.
PanosB_GR
Mon Feb 22 2010, 06:22PM
To jpsmith123:
I record the current, and does a "half-period" in about 1.5μsec. Since it is almost the waveform of a critically damped RLC circuit, with the capacitance (15pF) and resistance (~20Ohm) that i use, I calculate 10μH inductance, which is awfully high. Of course, some of it belongs to the external circuit. Nevertheless, the generator has the most of the inductance.
I have an idea for redesigning this bank, hope it gets better than that. ;)
Also, I was wondering, how can someone measure the self-inductance of the capacitors alone? This could be useful for determining the lower limit of the achievable inductance.
Mon Feb 22 2010, 09:18PM
PanosB_GR wrote ...
What is the risetime of your current transformer? (or the inductance of your current-measuring shunt resistor, if you measured the discharge that way?)
Charge a representative capacitor to a safe, low voltage (say, 10 volts), then short it through a bounceless mechanical switch (such as a mercury tilt switch) with attention to minimizing the total area of circuit loop. From the discharge voltage waveform, you can determine the effective series R and L of the circuit.
jpsmith123
Mon Feb 22 2010, 09:53PM
Are you using commercially manufactured capacitors or did you construct your own?
quicksilver
Tue Feb 23 2010, 12:07AM
Do you have a close up pic? Or pictures of it's gaps?
PanosB_GR
Tue Feb 23 2010, 03:18PM
To be honest I always assumed the current transformer would not be an issue. I have the pearson 1025 model,
pearson 1025 pdf
that says 4Mhz bandwidth, with useable risetime 100nsec.
The capacitors are commercially manufactured, oil sealed, in PTFE housing.
Here is a closeup of the bank. In fact, I realized that the total length of the current path per stage is huge, which is something i didn't thought in the first place. The spark gaps are made of machined aluminum, and the aluminum bars that hold them are 16mm thick. I made them this way, because it was convenient to adjust the distances...
1266937805 1680 FT83622 Imgp0183
jpsmith123
Tue Feb 23 2010, 05:06PM
OMG...words fail me...
