  • Guests: 48
need help about GDT winding
raff
Sun Jan 31 2010, 11:34PM Print
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
guys,
winding a 1:1:1 is EASY cheesey
but HOW do you PROPERLY wind a 1:2:2?
Mon Feb 01 2010, 09:11AM
If 1 = 10 turns then 1:1:1 will be 10:10:10.
If 2 = 20 turns then 1:2:2 will be 10:20:20
raff
Mon Feb 01 2010, 09:54AM
I know... ;D
but how is it wound ?
Mon Feb 01 2010, 10:19AM
A way to do it with low leakage inductance is:
Wind a 1:1:1:1:1 with a bundle of 5 wires all twisted together
Series up two pairs of windings to get a 1:(1+1):(1+1) = 1:2:2
For still lower leakage inductance you can take a piece of Cat5 ethernet cable (8 cores) and wind it round a ferrite toroid. Identify the 4 twisted pairs of wires. One wire in each pair is a primary, and you parallel them up, to get 4 parallel primaries. The remaining four wires are secondaries and you can series two pairs of them to get a 1:2:2.
If you're going to such lengths to minimize leakage inductance, then all of the leads going from the transformer to the gate driver and FETs must be in tightly twisted pairs too.
Mon Feb 01 2010, 10:40AM
You should also look at these links for reference and some formulas:
Link2 Link2 Link2 Link2
Mon Feb 01 2010, 02:44PM
raff wrote ...
guys,
Easy.
Say your turns ratio is 10:20:20 which is a 1:2:2 transformer.
1. Take three strands of wire and twist them tightly together using drill or similar
2. Wind all three strands 10 times through the core.
3. At the tenth turn, pull out a small loop of the primary wire a few inches out.
4. Continue winding the three strands an additional 10 times.
5. Cut the loop that you previous pulled out. You now should have the primary divided into two equal sections of 10 turns each
6. Connected the (4) leads of the primary now so that that you have two 10T primaries in parallel. Be sure to have correct phasing. VERY IMPORTANT
7. Voila' You're done!
You end up with 10T//10T:20T:20T or a 1:2:2 transformer
raff
Tue Feb 02 2010, 04:05AM
Hi Steve, Dan, 10111
thanks for the informative bits! cheesey
I finally managed to make one... 10primary (210uH) , 20T sec (around 800uH) x 2 with a leakage inductance of about 0.40uH.. I think its OK enough ...though I made it on a SMALLish TV flyback UU core..ferrite torroids (>1" OD)are VERY hard to come by...
some pics...
primary winding "bundled" whites..
1265083263 2315 FT83546 Img 3242
here is my core cheesey.. but it DOES work
1265083263 2315 FT83546 Img 3243
the secondaries
1265083263 2315 FT83546 Img 3244
its on my 2nd (soon to be DR) SSTC... secondary running on 218KHz with topload...
