  • Guests: 47
Is this coil "safe"?
cduma
Wed Jan 27 2010, 09:32PM Print
I decided that I wanted to build a coil that was safe enough to operate at school and work. At home I can minimize the risk/damage potential of HV feedback on the powerline but, I cant at school or work. Would this:http://www.instructables.com/id/How-To-Build- A-Vacuum-Tube-Tesla-Coil-VTTC/ be safe? I imagine that with an additional choke on the 120V side in addition to the 2.2KV MOT would "guarantee" the safety of other electronics on the same grid.
By safe what I mean is, is it far less dangerous than a SSTC? I have heard of many accidents that have happened with a SSTC that shorted out and arced to the powerline and destroyed everything that person holds near and dear.
Mrkva
Wed Jan 27 2010, 09:48PM
Mrkva Registered Member #2655 Joined: Wed Jan 27 2010, 04:09PM
Well, both SSTC and VTTC are usually powered directly by rectified mains (VTTC sometimes have MOT (like the schematics you've posted) or voltage multplier attached, thus are more dangerous). So the contact with primary ciruit (and especially when you're not perfectly isolated from the ground, or it's hand-to-hand contact) is usually lethal.
Usually, arc to the primary circuit kills almost every tesla coil so it's good habit to put one not closed turn of heavy gauge grounded wire few inches above the primary - which will prevent arcing from secondary to primary.
Wed Jan 27 2010, 10:42PM
What exactly do you mean by "safe?" Because its not clear in your post what you mean. Words like "safe" and "dangerous" do not typically apply to equipment susceptibility. They are used when dealing with "human health hazards."
radiotech
Thu Jan 28 2010, 08:45AM
Just another viewpoint about operating devices which have not been tested under categories for approval to sell, under the chain that starts with UL in the USA (for example) and passes down in laws at various levels: Do please consider people with biomedical electrics-
pacemakers for example.
cduma
Wed Feb 03 2010, 09:59PM
Is the risk of damage to items plugged into the same socket lower than a SSTC
Mrkva
Wed Feb 03 2010, 11:38PM
Theoretically yes - because in VTTC, you are separated from the electric network by transformer.
Wed Feb 03 2010, 11:45PM
Mrkva wrote ...
That statement makes no sense. I'll let you guys discuss further why its not true.
