  • Guests: 49
SGTC design review
Mrkva
Wed Jan 27 2010, 06:26PM Print
Mrkva Registered Member #2655 Joined: Wed Jan 27 2010, 04:09PM
Hello, I've already built a small Tesla coil (static spark gap), but I really like to try something bigger - and I'd be grateful if you check my design, if it's OK. (javatc data are attached).
Power supply - three phase MOT (Y-connection) PSU, 2 parallel at each phase (6 MOTs total), each pair has voltage quadrupler (1uF capacitors). Estimated output voltage without load 10-12kV, est. short-circuit current 0.5A. Each phase independently regulated using triac circuit.
Primary capacitor - MMC of KPI 300-047 (1uF, 1kV, 1kV/1us) 2 strings, 20pcs each. Total: 100nF/20kV.
Primary coil: 30x4mm FeZn grounding stripe, inner diam. 40cm, 7.5 turns, 6mm spacing.
Secondary coil: material: PE pipe, 30cm diameter, height of coil: 150cm, 1050 turns, 1.4mm wire (15AWG).
Topload: outer diam. 150cm, tube width 50cm.
Spark gap: yet to be decided... rotary, with adjustable BPM (ideally 200-400BPM).
Please let me know, if these parameters are OK and what should I improve.
Thanks!
]tc-javatc.txt[/file]
UPDATE: Changed capacitor type for one with better parameters (and thus also increased capacity), adjusted primary coil.
raff
Thu Jan 28 2010, 12:25AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
#15 awg? looks like a BIG coil to me :)
goodluck!
Thu Jan 28 2010, 09:01PM
Mrkva wrote ...
If this means galvanized iron strip, it will be an interesting experiment, since current wisdom has it, that only copper will doo.
Cheers, Finn Hammer
Mrkva
Thu Jan 28 2010, 11:31PM
Finn Hammer wrote ...
Yes, it's galvanized iron strip - the downside is that the iron has approx. 4.5 times greater resistance than copper. On the other hand, the copper is much more expensive. This is still a yet-to-be-decided topic.
Turkey9
Fri Jan 29 2010, 02:52AM
With much current going through that primary, which it sounds like it would, the iron would heat up A LOT. You really need to use copper. Copper tubing like used to connect refrigerator ice machines to the water source is pretty cheap. Available at all local hard ware stores too.
dmg
Tue Feb 02 2010, 05:14AM
for the spark gap, I think that using cheap thick steel electrodes might be in order (I belive using tungstun is a waste of money, with that much power I think the expence for the electrodes will add up fast, as your coil will eat them for breakfast.)
