  • Guests: 62
Inducktion (32)
Standa (31)
nabzim (33)
12/21 Inducktion (32)
12/21 Standa (31)
12/21 nabzim (33)
Opening up can type ignition coils?
HazzWold 1993
Tue Jan 26 2010, 11:16AM Print
Hey i was just wondering if anyone on here knew, which im sure at least one of you does, how to open those old can type iggy coils? i have 3 left and i wanted to run two of them in bipolar configuration, but ill be putting a lot of power and current through them, so tid be pushing the insulation to the max. so i was just going to run them under oil, and maybe vacuum.
thanks.
ragnar
Tue Jan 26 2010, 11:32AM
You need to unscrew the fastener inside the EHT terminal, then carefully peel the swaged metal lip of the can off the plastic rim, and the whole lot should lift out. Edit: drain the oil out the EHT first for minimum mess!
4HV Wiki > Ignition coils > construction
Antonio
Tue Jan 26 2010, 01:11PM
These coils are already insulated in oil. You can improve the insulation out of the case by putting the whole coil under more oil. Forget vacuum insulation. Too difficult. More practical is to use high pressure insulation. The breakdown voltage is directly proportional to the pressure. But oil is simpler.
Tue Jan 26 2010, 07:17PM
I'd just put the unmodified coils under oil...
On the topic, what spark length can a typical ignition coil stand?
Tue Jan 26 2010, 07:29PM
Dr. Kilovolt wrote ...
Discharge a film cap into the primary and you just might find out wink. I have seen people do like 6 inch sparks with a couple iggys. That does not necessarily mean any kind of CW, but i bet you could do 6 inches with a single coil if you discharge a cap into the primary. It would not last long...
I have taken iggy coils apart. I just used a pair of wire cutters, and i cut along the metal lip a few places to make it easy to peel back. I did not take the screw out. It connects the plastic top of the housing to the transformer itself, but to take the transformer off of the plastic you also have to disconnect the primary terminals. Just unscrew the nuts, the bolt should drop through, i think.
HazzWold 1993
Thu Jan 28 2010, 10:46AM
Ive pushed 100Kv sparks out of a can type ignition coil, but even under oil itself i could hear crackling under the oil of it arcing
