  • Guests: 34
Problems with PWM audiomudulation over UCC37321 enable pin
Mates
Fri Jan 22 2010, 12:46PM Print
Hi guys, I run into limitation of the enable pin of UCC gate drivers. I experience this problem: Once I set the PWM based interrupter to frequencies over few KHz my coil stops working.
My point is to achieve something similar I already did before but using two TL4894 instead. I used one of TLs to drive the coil in a fixed resonant frequency (170KHz) and the second one was driving the power supply of the first one over FET transitor. The second TL494 was set to 50 KHz with 25% duty cycle and PW audiomodulated. The coil reproduced sounds quite well but with strong 50Hz distortion because it was running in half rectified mains mode – here you can hear my voice reproduced by the coil Link2 . Why I cannot use the same approach for the enable pin of UCC? I mean simply setting the interrupter to 50 KHz and audiomodulate it’s PW?
ragnar
Mon Jan 25 2010, 11:15AM
Hi Mates,
The ENBL pin on the UCC is significantly slower than IN. I observed this when I had thought it was clever to wire IN/ENBL together to simplify my PCB layout.
Steve Conner also had poor performance from the ENBL pin using it for a dead-time application, IIRC. If you've already made your PCB, you may be able to get away with some mickey-mouse logic on IN, instead.
Tie your ENBL to VCC, put a 10k resistor in series with IN, and allow your ENBL signal to pull it down through a 1N4148, and see if that works any better.
1264418132 63 FT82985 Mmenbl
Mon Jan 25 2010, 11:34AM
I think the delay time of the enable input of the UCC is something like 60ns vs. 30ns of the input pin. I think you wont notice that in real life...
Are you using some kind of feedback? Maybe it doesn't have the time to lock at such high interrupter frerquency.
@Blackplasma: Your circuit can't be used with two UCCs in push-pull configuration, because pulling the interrupter input down results in one UCC output high and the other low, however you want to have both low.
Goodchild
Mon Jan 25 2010, 04:12PM
umm just a thought but why do you want your interrupter at such a high frequency? I never really go above 500Hz on any of my coils.
ragnar
Mon Jan 25 2010, 05:14PM
Here's the relevant thread with Steve's note: Generating deadtime, second post - ENBL pin is clearly quite picky, avoid where possible...
Dr. Kilovolt wrote ...
Thanks Jan, you're right - I only get away with it because I'm hardcore and only use noninverting UCCs on principle.
