  • Guests: 44
Pyromaniac (34)
Wavetuner (76)
jeffomatic (75)
SparkLabs (36)
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
help me to connect driver circuit ir2110
kamal
Wed Jan 20 2010, 06:19AM Print
kamal Registered Member #2642 Joined: Wed Jan 20 2010, 06:13AM
actually,a dont know what value to use in ir2110..such as value for capacitor,resistor,diode,VDD,Vcc...pls hlp me
hboy007
Wed Jan 20 2010, 09:51AM
as this is your first post: welcome to 4hv.
It would be quite helpful to know what you are up to so please give us a short summary or circuit drawing.
What are you driving with the IR2110?
What is the load (inductive, resistive, capacitive?)
What supply voltage and driving frequency do you want to use? (the datasheet is always looking over, just google it if you haven't done so already)
There are a lot of skilled people here, so be so kind as to keep in mind: good questions are half of the solution smile
cjk2
Wed Jan 20 2010, 04:41PM
The datasheet for that part will be very helpful as will a description of what you are trying to do. After you have reviewed the datasheet and looked at any app notes you can find, you will likely be able to answer your own questions.
