  • Guests: 52
  • Members: 1
SSTC Class-E Steve Ward Project
karek
Mon Jan 18 2010, 01:16PM Print
karek Registered Member #2637 Joined: Mon Jan 18 2010, 12:47PM
Hi,
i built tesla coil by Link2
But doesn't work, but the discharges are Mosfet is hot just like I tried to adjust its power supply capacitor resonant but it does not produce a good effect.
I designed the pcb, it is good
I use 5*3,3nf/2kv cacpacitor C6=16,5nf
And 4,5turn on primary.
My Secondary coil is:
193mm High
on 110mm pipe
Primary coil 160mm
1 to 12truns 1,5mm
I use IRFPS38N60L insted of irfp460
Sch:
Photos:
35 1263820144 Thumb 64 1263820144 Thumb
Video:
After this video mosfet and power supply is hot.
I have no strength to do that Tesla turn to you with this problem. Sorry for my English because I'm the only Polish, and I learn.
Mon Jan 18 2010, 08:48PM
There is really not enough info to help you. We could validate whether or not your circuit board is good, but it could be a bad solder joint, misplaced wire, flux that is shorting something, or perhaps the sun is just having a bad day.
Waveforms could be helpful. Maybe go over your circuit again yourself? You are just as capable finding a fault in your circuit board as us. Even better, in fact.
