  • Guests: 54
advanced modulator doesn't work in multisim
tritium
Sun Jan 17 2010, 10:14AM Print
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
hello guy's,
I have drawn the simple AUX circuit (advanced modulator from eastern voltage research) in multsim, if I put the scope on it i get an constant 5 volt output to the scope, powersupply is 9V,
does annybody know's what Im doing wrong?
if it work in multisim, then I can see what happens to the pulses and connect the pot.meters correct when I start to build the interrupter.
doctor electrons
Sun Jan 17 2010, 02:18PM
Post a screen shot. That would help everyone see exactly what you have going on wink
tritium
Sun Jan 17 2010, 06:25PM
here is a picture scan of the multisim/schematic
1263752719 2591 FT82681 P1
doctor electrons
Sun Jan 17 2010, 10:04PM
In the shot you have there, the dc voltage of your supply is set to 5v.
Double click on it and change the output value to 9vdc and see what you get. wink
tritium
Mon Jan 18 2010, 06:15PM
yes, that is because I was playing with it, I tought it was maybe a cmos device, so I changed to 5 volt (maybe the software will kill the device) cheesey , but also on 15 volt or 9 volt I get an continue output of 5 volt, nothing is oscilating.
but for this, the only thing wat I want to know, is that if I have the pot. meters turned to the left (minimal prf/ms/us/pw/dwell/lock-out) where the arrow will be in the schematic's, up or down.
Mon Jan 18 2010, 06:38PM
1. Does Multisim require a ground node? I know PSPICE does?
2. Are you doing a transient analysis? If just doing a bias point analysis, then all you will see is a DC voltage.
3. Is the 555 model even a working model?
doctor electrons
Tue Jan 19 2010, 12:01AM
Multisim does require a ground node to run simulations. I should have caught that!
If multisim detects a problem with your circuit it will stop the simulation and your scope or meters "may"
lock at the last working measurement. When you hit the "play" button to run the simulation, if there is a problem, it
will open a dialog box that tells you the problem and/or problem area. If you pulled the 555 out of the built in component
list then it should be just like the real deal. If you just drew it in and named the pins without giving any parameters, it will not
do anything.
Tue Jan 19 2010, 10:50AM
I'm going to quote Bob Pease here... If the real circuit didn't work but the simulation did, would you complain to Multisim? tongue
EVR is a professional engineer, so he should have documented which way to turn every pot on the schematic and PCB artwork.. (yes that's a joke, this is hardly ever done in industry and I wish it was smile )
tritium
Tue Jan 19 2010, 04:39PM
@evr,
1 no, it is oscilating when I draw an other circuit like the PRF Adjust
2 don't know, because I'm working with this software fore one week now, gonig to try if there are options in the software
3 yes, see 1
but you are the men in this one, can you tell me where the arrow should be stand in the drawing versus stand of potmeter?
Tue Jan 19 2010, 09:14PM
Steve McConner wrote ...
Oh no! Not Bob Pease please!
wrote ...
@evr,
3 yes, see 1
I've had mixed luck with 555 timers using PSPICE - mostly because the models are usually hit or miss.
Your best bet is simply to wire it up on the bench and play around with it there. Also, the equations are very simple for a 555 so a simple excel sheet should provide the information you need.
wrote ...
To quote Bob Pease again, "If i actually knew *what* you were talking about here, i'd surely answer your question. Proper english goes a long way to clear up confusion."
Czar
