  • Guests: 58
Coaxial N2 laser?
Sat Jan 16 2010, 01:55PM Print
B. Oliveira dos Santos, C. E. Fellows, J. B. de Oliveira e Souza, and C. A. Massone
“A 3% Efficiency Nitrogen Laser”
Applied Physics B (Photophysics and Laser Chemistry) 41 (1986), pp. 241-244
This is a strange and wonderful article that illustrates an entirely different approach.
Using a coaxial capacitor of only 800 pf, driven by one of three “dumper” caps (1.5, 10, or
20 nf), they achieved up to 3 MW output power at efficiencies ranging as high as 3%.
Peculiarly, their pulsewidth decreased as the amount of stored energy increased, which may
suggest that they are pumping a substantial fraction of the nitrogen molecules in their
laser. Well worth reading and thinking over very carefully.
this is intriguing.
by "coaxial capacitor" i assume that they are using an outer copper/etc tube with an inner
wire electrode.
would make sense that this would work,but the tube would have to be *exactly* the right
diameter and perfectly planar to work at all (so likely the B&Q tube wouldn't work)
the best way to achieve this would be to securely clamp and fix the outer tube in place in
multiple locations to a wooden block, and use glass feedthroughs at each end to hold the
wire.
By adjusting the wire diameter (easily done) the cavity gap could be adjusted and once set up it should be stable for quite a long time.
Interestingly such a setup could be used with pc board as the ground plane *only* for
mechanical stability with the tube(s) soldered to a groove in the board.
comments?
-A
Sat Jan 16 2010, 05:58PM
Registered Member #2372 Joined:
So did you actually read the paper or do you not have access? because the discharge is still just between two electrodes that are parallel, but this is fed by a coaxial capacitor that is pulse charged from another LC circuit. This is actually a pretty typical way of making a very fast LC circuit where a marx or something pulse charges an intermediate storage capacitor that is frequently a coaxial design with water as the dielectric. The intermediate storage capacitor is then discharged into the load. A coaxial capacitor can be made with whatever dimensions you want in order to minimize the inductance so it can be made as fast as needed. If you want the paper I can email it to you.
brtaman
Sat Jan 16 2010, 06:47PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
dugg wrote ...
If you have access I would greatly appreciate, if you could mail me the paper.
Best Regards,
brtaman
Sun Jan 17 2010, 08:50AM
comments?
N2 laserists and PFN geeks might appreciate the free online article where that paragraph apparently came from: Link2 Retaining that credit is not only the right thing to do, it's on-topic for this 4hv thread. Though its author Jon Joss could be less peevish (as could I).
We all have access to the cited Applied Physics B article:
You would have to read the terms & conditions, to see if it's legal to pay for 1 copy and then email it to your friends. The analogous traffic in popular music and movies is a subject of vigorous debate.
Sun Jan 17 2010, 10:03AM
Coaxial lasers generally work as pulse forming lines to keep inductance as low as possible and to double the voltage available for the discharge when a hydrogen thyratron/pseudospark/spark gap switch is closed.
Jitter is least when the electrodes are made from material with a low work function such as aluminium.
brtaman
Sun Jan 17 2010, 02:57PM
Klugesmith wrote ...
I have a few scientific contributions in the field of management and economics and I could care less, if the entire world has an unpaid copy of one of my articles...if it benefits the science of business I am all for it as long as any article stemming from my work cites the source.
If I was planning on using their research for commercial purposes I would be more than willing to pay, but for a quick home-brew experiment the asking price seems a bit stiff to me.
Sun Jan 17 2010, 03:59PM
brtaman wrote ...
if the entire world has an unpaid copy of one of my articles... I am all for it as long as any article stemming from my work cites the source.
I feel that way too, about my own feeble contributions to the world of published wisdom.
Agreed. My main point was that if a hobbyist really wants to read a cited journal article, he/she no longer needs to visit an academic library -- the paper can be had immediately via the Internet. Compliance with IP copyright rules is a matter of personal choice -- judgement of rightness, wrongness, and enforcement. I've paid as much as $20 to read papers relevant to significant hobby projects. But when Google showed me a copy illegally posted on a college student's website, I did not snitch -- I grabbed a copy right away. smile
Mon Jan 18 2010, 12:49AM
it occurs to me that excessive copyright and misuse of patents stifles creativity and innovation.
case in point, the blatant misuse of the patent system on the human genome when the companies involved are doing so purely to stop anyone else doing research on "their" IP.
just my $0.02 worth.
wouldn't the world have been a better place if the patent system required *use* of an idea to validate the patent by a sensible deadline or it became public domain. "First to market" not "First to patent" and all that.
