  • Guests: 43
(OT) Printers from Hell
Tue Jan 12 2010, 06:17PM Print
NSFW, NSF.. etc ....
FWIW I have had the mother of all paper jams on an Epson R600 before, requiring the services of:- a pair of locking hemostats, tweezers and a fine screwdriver to remove. And required cleaning the rollers with IPA before it deigned to print again.
my best one was on an hp all-in-one. someone had dropped a little plastic divider from something in there, that was an (insert invocation of your choice) to remove.
once found a Kyocera laser printer someone had chucked because of paper jams, with full cartridge. Used that for a couple of years before it went to Silicon Heaven (or Hell, if Epson/HP/etc)
-A
#include " Whyohwhydosmallcarsneverfitthefrellingsnowchains.h "
Reaching
Tue Jan 12 2010, 10:06PM
hrhr. never had an inkjet, dont want to buy one^^ mhh, now i know it was a good choice....
lasers forever°°!---> prints 5000 sheets of paper without buying new toner cartriges, and without getting in trouble....
thedatastream
Wed Jan 13 2010, 08:43AM
hahahaha awesome website
that's going to keep me chuckling today
it's like he owns my printer!
Bored Chemist
Wed Jan 13 2010, 10:13AM
Mutter mutter £25 printer that takes £30 cartridges mutter mutter.
Will
Wed Jan 13 2010, 01:41PM
Will Registered Member #57 Joined: Thu Feb 09 2006, 05:28AM
Hahaha, that's great. I'm like Reaching, I've not experienced this horror due to using laser printers. :D
For more on the love of printers, see You Know What's Bullshit Episode 8: Printers
Here's the rest of the series.
Wed Jan 13 2010, 10:28PM
Hah, quite amusing.
I find this one to be perfect for the forum. Link2
It mentions Nikola Tesla, and i know Noelle and Kizmo have/love cats.
Enjoy
Matthew.
Turkey9
Thu Jan 14 2010, 02:16AM
I've heard from the brother of an HP employee that HP ink is the most expensive liquid on earth.
Thu Jan 14 2010, 06:39PM
i have half a dozen hp all in one printers here.
interestingly they have parts which are truly cool for making Repraps etc, such as the actuators and precision cut bearings.
anyone have a use?
also have an epson label printer with thermal AND dot matrix modules, seems a shame to trash it. PM me if anyone has a use.
includes steppers galore...
Its a bit heavy at 8 kilos but most of that is the casing.
Fri Jan 15 2010, 05:30AM
Conundrum wrote ...
... anyone have a use? ...
Ah yes, how to make a stepper motor turn without fancy electronics? Typically you need two bipolar or four unipolar pulse trains, 90 degrees out of phase.
Well, one way to create such a signal is ... use another stepper motor as a generator!
1263533038 2099 FT82448 Dscn0895
This demo has 2 steppers and a connectorized 5-wire cable, all pulled from a printer. No soldering after they left the factory. When you turn the pinion of big motor by hand, rapidly enough, the small motor turns by the same angle. smile
Carbon_Rod
Fri Jan 15 2010, 07:37AM
Continuous Ink Flow Systems are $40 if you get a kit, or less if you make your own.
The old laser printers generally outlast the computer...
still printing... and slowly oozing cigarette stain yellow fire retardant.
