  • Guests: 51
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
induction heating levetation
Mon Jan 18 2010, 04:44AM
you have got to see this!
Here I am levitating, melting and boiling aluminum like a mini sun, suspended in a magnetic containment field.
I start at 1.5kw and bring the power up to 2.5kw. I am still afraid to just turn it on full. The aluminum spins because it is uneven in the field. Eventually, it liquifies into a sphere, which I poke like a soft marshmallow. The magnetic field is strong enough so the molten mass does not slip through the center. It is probably not evident on the video, but I can see it boiling. Finally, I release it and it plops onto the floor and immediately solidifies.
The levitation is very stable and the mosfets were all cool to the touch. The PLL-integrator held onto the lock just perfectly.
I have also liquified copper and will get this on video next.
Dinges brings up the point about the series diode. With regards to the schottky series diode 1n5822 I looked at the datasheet and it has an average of 3.0A forward current. How can this work when the mosfet sees 20A or more through it? Steve or Richie?
Experimentonomen
Mon Jan 18 2010, 08:39AM
Nice!!
GeordieBoy
Mon Jan 18 2010, 11:40AM
My mosfets blew because I was out of resonance. The piece of steel shorted some of the coils, lowering the inductance. This put me in a zone where capacitative reactance was greater than inductive, and this is bad for the mosfets
The series drain schottky diodes are to prevent this type of failure. Otherwise you get forced reverse recovery of the MOSFET body-drain diode whilst driving a net capacitive load.
Also note that one of the advantages of the parallel resonant LCLR network is that it is inherently fault tolerant of the work coil getting short circuited. If the work coil gets short circuited by the workpiece (or the tank cap should go s/c) then the inverter just sees the impedance matching inductor as its load. The inverter load current falls to a small inductive (lagging) current which is safe for the inverter until it is shut down. (Contrast this to short-circuiting the work-coil in the series resonant topology where the tank capacitor gets discharged into the output of the inverter. The on-going load is then capacitive for a complete or partial s/c of the work-coil)
-Richie,
Mon Jan 18 2010, 11:51AM
Yes very nice! smile
IamSmooth wrote ...
Well, a 1N5822 is obviously not a good choice for the schottky! Other bigger schottkies are available.
Mon Jan 18 2010, 01:18PM
IamSmooth wrote ...
That's really cool, isn't it?
Hell yeah! Excellent demonstration Jonathan.
Mon Jan 18 2010, 04:43PM
Steve McConner wrote ...
I have found a few schottky choices. They are all fast. The parameters I am toying with is the reverse voltage. How much is enough? If I have 340v, each mosfets sees half. So would this be overkill?
With regards to the free-wheel diode, does the reverse voltage have to equal the drain-source potential? If that is the case, I could have 170vdc.
How is this? Link2
Also, what is so bad about capacitive loads? Why does this type result in failure compared with inductive?
Mon Jan 18 2010, 04:53PM
The reverse voltage of the Schottky just needs to be a few volts. It only ever sees the Vf of the main freewheel diode, give or take some transient voltages. In practice 20 or 35V would probably do.
The freewheel diodes need the same voltage rating as your MOSFETs: 500 or 600V.
GeordieBoy
Mon Jan 18 2010, 04:56PM
For Schottky diodes blocking the body diode of a MOSFET, 30 or 40 volts PIV should be plenty as long as you provide an alternative path for the free-wheel current.
Each MOSFET does not see half ! They both see the full 340v plus any switching spikes and ringing
However, the off-state voltage of the MOSFETs is irrelevant for rating the Schottky diodes. If you are thinking of using those diodes for free-wheel duty their 200V rating will not be sufficient. You'd be better with a 500V or 600V Ultra Fast recovery Silicon diode.
Yes, ideally it would equal the MOSFETs Vds(max)
Not if the DC bus voltage is 340V, you can't!
As I said in my last post. A net capacitive load on the inverter causes the free-wheel diodes to be subject to forced reverse-recovery. The load current changes direction before the applied voltage (capacitive load gives leading PF) so the route that the load current takes through the inverter changes before the MOSFETs are told to switch. When the MOSFETs eventually are told to switch, the current is flowing in the "wrong" free-wheel diode so these diode turns off rapidly and "under duress" If you use ultra fast recovery silicon diodes as free-wheel diodes and a tight layout to minimise stray inductance this is not too much of a problem, but if you try to use the MOSFETs body-drain diodes as free-wheel diodes with a net capacitive load or if the layout is sloppy then you are in for a miserable time.
-Richie,
Mon Jan 18 2010, 05:36PM
I feel dumb. I understand now: capacitive loading just refers to the direction the current is going through the mosfet. It is reversed at this time.
I have been looking for some parts for the inverter, but have been having trouble finding some in the 30-40A range. I found a 40A schottky that seems good, but it is surface mount. Link2
This isn't a big problem, as I have the heat station for it. I want to have some headroom above 30A. Do you know of any through-hole style for +40A schottkys?
I guess the MUR1560s are a good choice using a pair for the free-wheeling diodes.
Nicko
Mon Jan 18 2010, 05:59PM
This is what annoys me - In the UK (e.g. from Farnell) the MBRB4030G is £4.14 or USD 6.77. RS don't even stock it.
From Digikey in the US, its USD 3.70.
Both in Qty 1 pricing.
Pah.
