  • Guests: 51
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
CO2 Laser Resonator Mirrors on eBay
RickR
Sat Jan 09 2010, 06:53PM Print
RickR Registered Member #93 Joined: Thu Feb 09 2006, 04:11PM
I'm not selling them myself, but I did order one set of CO2 Laser Cavity Mirrors off eBay. These mirrors seem suitable for a DIY CO2 laser. The cheapest mirrors I have been able to find before would run around $150.
Again, I'm not related in any way to the seller other than as a purchaser of their product.
RickR
turbohead
Tue Feb 23 2010, 10:17PM
turbohead Registered Member #1037 Joined: Sun Sept 30 2007, 02:41AM
The reflectance of the output coupler (92%) seems high. Most 30 to 50 watt lasers designs I have seen recommends about 85% reflectance.
RickR
Wed Feb 24 2010, 06:07PM
Well, I chose the mirrors based on the design I found on this website: http://www.timefracture.org/laser.html.
This design used a 92% OC. Once I hit a slow spot with my high voltage experimentation, I plan to implement this particular design.
RickR
turbohead
Wed Feb 24 2010, 08:50PM
You may want to review Sam's FAQ in detail:
The FAQ provides tables of optimal reflectance for the tube length/tube inside diameter configuration.
For example, the design in the Timefracture website is a 1.2 meter tube. For a 15mm ID tube, the theoretical reflectance is 65%.
A 92% mirror will work, however, if you want more power, you will quickly outgrow the 92% reflectance mirror.
Another point of reference:
specifies an 80% reflectance output coupler.
Just trying to help.
RickR
Wed Feb 24 2010, 09:32PM
No problem, I (and I'm sure others as well) appreciate the additional information.
BTW, do you have any favorite sources for mirrors/couplers with reasonable prices? I jumped at this set because it seemed relatively cheap.
Thanks,
RickR
turbohead
Wed Feb 24 2010, 09:50PM
I have purchased several CO2 laser optics from:
The owner is Bruce Sunderland. Bruce has been very helpful with advice and supports those who are making CO2 lasers as a hobby.
His prices are competitive. Bruce is also mentioned in Sam's FAQ.
aonomus
Thu Feb 25 2010, 05:21AM
Not to derail, but if you don't trust ebay, Link2 is a commercial optics website that caters to high level stuff. Expensive though, but they'll certainly carry what you need, and probably give you advice too.
