  • Guests: 34
plasma ball to a mini tesla coil
audio:deviant
Mon Dec 28 2009, 03:45PM Print
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
hello all, i pulled apart my old plasma ball and wanted to juice it up a bit and use it as a mini coil. works a little differently than i thought.. how can i make the arc bigger, theres a black box that i presume is the a flyback transformer.
lpfthings
Tue Dec 29 2009, 06:17AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
You can try applying slightly more voltage, but apart from that you can't do much else, they simply aren't designed for high power.
audio:deviant
Tue Dec 29 2009, 12:00PM
no im beginning to realise that gets very hot very quickly! thought i have a go at a micro sg coil instead, secondary size of about 8cm by 1cm!
