  • Guests: 31
Reaching (40)
ryanshow (38)
07/22 Reaching (40)
07/22 ryanshow (38)
07/23 Will (38)
Just wanted to show my Induction Heater in action
teravolt
Sat Jan 02 2010, 05:09AM
thanks Jonathan, its alot to absorb bought some mica caps on ebay they are from custom caps .1 @ 750ac I have to see if they will be sutible. cheers.
Sun Jan 10 2010, 11:51PM
I have gotten over 3kw of input power going through the mosfets. I measured at one time that 90% of that was making it into the coupling transformer. I am working on improving the coupler.
Here is a video showing 3kw melting aluminum. Near the end you can see molten metal dripping onto the metal plate at the bottom.
doctor electrons
Sun Jan 10 2010, 11:57PM
doctor electrons Registered Member #2390 Joined: Sat Sept 26 2009, 02:04PM
"Can any of you tell me where I can get a crucible that can withstand molten steel? I saw Kimlaha use some asbestos-looking container and cover in his video. If I can contain the radiating heat I should be able to make a molten bath of metal in a few minutes."
[/quote1263167811]
Nice work!! Try this place Link2
Pricing is very reasonable and there is a catalog you can download for free!
Mon Jan 11 2010, 01:20AM
Thanks. I actually bought one from them. I got that one and it couldn't stand the heat. I think the problem is my crucibles are too thin and the heat/cold shock is destroying them.
doctor electrons
Mon Jan 11 2010, 02:10AM
Bummer! My bet would be that you are 100% correct about the shock. These things are very fragile!
Maybe they could suggest a different material? Call them and get some free info, they know more about
the materials than i do. Just thought the low cost would be what you were looking for. I work 2 buildings away from
Pillar induction, i will take a trip over there on my lunch break tomorrow and ask them what they use. wink
We do quite a bit of business with them!
Mon Jan 11 2010, 06:50PM
preheat the crucibles with directed hot air (koff solder rework station /koff) maybe?
then keep the heat on after switch off and back off until near room temp.
just my $0.02 worth.
-A
Mon Jan 11 2010, 07:45PM
I think the preheat is correct based on my conversations with some metallurgy companies. I was just cranking it to 2000f within a minute.
I also plan to make a coil for levitation, so that will solve the crucible problem. I will just melt the metal in mid-air. So it hope.
doctor electrons
Tue Jan 12 2010, 01:50AM
Well,... Stopped by Pillar like i said i would! They told me that cracking crucibles is in fact a matter of temperature shock.
They told me that ,, "Induction heaters are cabable of delivering extreme amounts of energy, concentrated on a small
amount of space, in a very short period of time." "Most crucibles are kept warm in an oven before and after being used." So
it sounds like a normal one will work if you have a way of always keeping it warm and dry! I guess you have to just treat it
like its your only child
Tue Jan 12 2010, 02:40AM
doctor electrons wrote ...
Always be prepared to empty the crucible (pour out all molten metal) while hot.
If you let a substantial amount of metal solidify in the crucible,
any attempt to re-melt it will probably crack the crucible as the solid metal expands.
Nicko
Tue Jan 12 2010, 04:46AM
Nice project.
Is that two Tek P5210s there? That's about USD 5,000 of differential probes (connected to a 'scope worth a fraction of that)! Work or personal?
