  • Guests: 58
Spiraform TC streamers & hydrogen/oxygen explosions
Herr Zapp
Sun Dec 27 2009, 09:25PM Print
Most everyone has seen photos of straight "sword-like" Tesla coil arcs with superimposed "spiral" features. The majority of the of the photos that I have seen were of discharges created by VTTCs, but they have also been noted on SSTCs.
There have been several theories proposed to explain the spiral features, but I don't know that there has been a universally-accepted answer.
While researching high-speed photography, I came across some images of exploding balloons filled with hydrogen/oxygen gas mixtures. The ignition of the compressed gas mixture produced the expected bright fireball, but what was unusual was the presence of straight, spiriform streamers extending out from the center of the fireball. These are remarkably similar to the spiraform streamers seen in some Tesla coil discharges.
I have no new insight into how Tesla coils generate spiraform streamers, and I have no idea if there is any commom physical phenomenon behind Tesla coil streamers and the streamers generated by the hydrogen/oxygen explosions, but the similarity in appearance is amazing.
See the negative image in the second column, third from the top: Link2
I'd be interested to hear of anyone's explanation for this ......
Regards,
Herr Zapp
Sun Dec 27 2009, 10:13PM
My guess is that the spiral streaks are just the trails
of solid ejecta (such as latex balloon fragments).
A few of the flying bits are spinning or tumbling.
[edit] Balloon fragments might get a lot of non-radial momentum from their own elastic contraction.
plazmatron
Sun Dec 27 2009, 11:29PM
Yes, I go with the fragments theory regarding the balloons too.
With regard to streamers, I have observed this too, and the spirals are quite tight an regular. My guess is that the magnetic field of the TC is twisting the plasma in the streamer as it grows.
Les
Mon Dec 28 2009, 05:14AM
Registered Member #2372 Joined:
There is a generic plasma instability called the m=1 or "kink mode" in which a straight current carrying wire or plasma column will tend to make a spiral shape. This could be the cause of the spiral features in the tesla coil streamers you speak of. Knowing the current etc. one should in principle be able to run through the math and determine if this is in fact the cause.
Much in the same way that two parallel current carrying wires are attracted to one another or antiparallel wires push away from one another any current carrying system will act to increase its inductance.
Mon Dec 28 2009, 11:26AM
Isn't that because of the "Z-pinch"? They mention a Tesla coil on the wiki page: Link2
Mon Dec 28 2009, 05:17PM
The Z pinch doesnt cause a spiral shape. The main instabilities for a current carrying channel are the M=0 sausage mode and the M=1 kink mode. The Zpinch just leads to the channel being compressed on axis (JxB force, or directly from the Lorentz force), during this compression process the m=0 or m=1 modes can be excited.
plazmatron
Tue Dec 29 2009, 05:09AM
Hmmm, I feel an experiment coming on!
Looking at the pupman archives, there are indeed many theories, including air currents,magnetic field interactions, various plasma instabilities etc.
I`m going to have to dust off the old VTTC, and try some stuff out methinks. Little nagging questions like this bug me!
Les
Avalanche
Tue Dec 29 2009, 12:24PM
The spiral streamers have always fascinated me too, and over the last few years I haven't seen a definite explanation for them. Very similar formations can be seen on VTTCs and on SSTCs which have a halfwave input, however the VTTCs always seem to produce the most impressive effect (as they are usually halfwave too). The effect appears to be definitely down to the shape of the RF envelope coming out the top, and for some reason half sine waves produce long swords..!
After working in a company which design and produce high power inverter products of various frequencies and outputs for the last couple of years, I have always meant to try bizarre shaped waveforms at different frequencies (just software changes in the inverter) and see what happens to the spark appearance! What kind of swords would come out the top if the AC waveform has some 3rd harmonic? If people are interested, I might hurry up and post some results one day smile
Wolfram
Tue Dec 29 2009, 05:58PM
Avalanche wrote ...
I've been having this same idea in the back of my mind for a long time, and I am sure you would get some very interesting results. I did some primitive experiments that seemed to show that a faster rise of the RF envelope produced more VTTC-like sparks than with just standard half-wave rectified mains. This is certainly only valid up until a certain point of course, as interrupted SSTCs, with a very very fast rise don't make very swordlike sparks at all.
If you have the possibility to try this out, I would be very interested in seeing some results.
Anders M.
Marko
Tue Dec 29 2009, 10:46PM
Hello guys,
dugg wrote ...
This is turning genuinely fascinating for me - could you please elaborate it a bit?
Are you saying that a current-caryying plasma channel tends to increase it's inductance by twisting itself into a coil? :O
Z pinch is rather simple to visualize, but twisting effect on tesla coil streamers isn't. It also only seems to be happening with low current, long duration streamers and not on short-lived high energy streamers of disruptive TC's, what is the reason for that?
