  • Guests: 41
And you thought you were obsessive compulsive....
Sun Dec 27 2009, 11:01AM Print
"I once worked at a place that had a DEC/VAX mini with a bank of about 8 modems for VT100-compatible terminals. If there were modem complaints such as dial-in problems, I had to first figure out which modem was connected to which phone number. Others didn't always keep the map up-to-date. Plus, it used busy-roll-over.
The test phone was a ways away from the modem bank for the VAX minicomputer, so I had to keep the modem trying to connect long enough until I got there to see which modem answered the call (via LED). The only easy way I found to do this was to manually whistle an acceptable modem tone into the phone in order to trick the modem into thinking I was a modem trying to connect. This would keep it trying long enough to allow me to run from the test phone to the modem bank. It had to be the right pitch and wavering to work most of the time. I got pretty good at it after a while. I learned to "speak modem" a bit.
A computer-room technician once saw me whistling modem sounds into the phone and running back and forth. I later told him why, and he told me I was nuts and mumbled something about whistling sweat nothings to my robotic girlfriends."
(found on slashdot)
-A
Experimentonomen
Sun Dec 27 2009, 11:24AM
LOL cheesey
Turkey9
Mon Dec 28 2009, 06:24AM
Maybe that guy was one of the original hackers! You know, the ones that used tone sequences to get free calls? smile
Mon Dec 28 2009, 11:32PM
I'm in your phone, hacking your minutes...
Plasma Lover
Thu Jan 07 2010, 06:38AM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
Turkey9 wrote ...
You mean a 'Phreaker'?
They only had to use a single tone (2600Hz), and they were sometimes known as 'Crunchers' due to the fact that, for a while, a Cap'N Crunch cereal box came with a free whistle which had a frequency output of exactly 2600Hz.
