  • Guests: 51
  • Members: 1
UK / Europe Junk Box
1 2 3 4
Sat Dec 26 2009, 03:15PM Print
GalliumMan Registered Member #2571 Joined: Sat Dec 26 2009, 12:02AM
Wiki page: Link2
Hi All,
The new Junk box is almost ready to ship. I think Conundrum said he would like to go first.
How do i get your address Conundrum?
List of contents:
1 x Scantronic 200 Passive IR Sensor
1 x Smart ID WiFi Detector - may need new batteries.
1 x D-Link Air Plus G PCMCIA Laptop Wifi Adapter
2 x Large Motors
2 x 8 Ohm .5w Speakers
1 x 8 Ohm .25w Speaker
2 x 4 Ohm 3w Speakers
1 x 10A 250v DPST Switch
1 x Mullard DY802 Valve
1 x Mullard PC97 Valve
1 x Pinnacle UCL82 Valve
1 x Pinnacle 6F28 Valve
1 x Pinnacle P698 - PCH200 Valve
1 x Pinnacle P654 - PY88 Valve
1 x 100x220mm Single Sided Copper Clad Board
4 x 6v Self Flashing Bulbs - the ones with the bi-metalic strip in.
1 x Red / Black Female Banana Plug Socket
2 x Black Black Female Banana Plug Sockets
1 x UK Mains Socket
3 x 3 pin PCB Sockets - Male and Female
2 x Hard Drive Motors
1 x Small Reel Bell Wire
3 x Magnetic Ended Cables
1 x 150x80mm Project Box (Black ABS)
1 x 60x32mm Project Box (White ABS)
1 x Cold Catgode High Voltage Driver (the small blue box with the switched lead)
1 x Lepai Mosfet Stereo Power Amplifier
2 x Female Euro Plugs
2 x 120mm Fans 12v
1 x 60mm Fan 12v
1 x pack of assorted Capacitors (I'm not going to List individual values)
2 x LARGE 2200uF 400v Electrolytic Capacitors
1 x 500v 4uF Paper Capacitor
4 x Packs new Draper Needle File Sets
4 x 70mm Work clamps
4 x Packets Loctite Glue Gun Sticks
4 x Banana Plug Crocodile Clips
20 x 12v 1.5w Minature Lamps
1 x Strip 5A Choc Block Connectors
1 x Strip 10A Choc Block Connectors
1 x Mystery Transformer / Inductor - not bothered measuring and can't remember where i got it.
1 x 6-0-6 PCB Mount Transformer
2 x Compact Fluorescent Bulbs - no driver circuitry!
1 x Roll Earth Coloured Insulation Tape
1 x Large Dulmison Insulator
Sat Dec 26 2009, 09:22PM
You can pm Conundrum, I'd also like to participate with this box. Hope it doesn't go missing like the USA or EU box that's already in circulation.
Sun Dec 27 2009, 01:12AM
yep, i have lots of junk to add...
Am hoping that those Russian tubes show up (the multidigit vfds) :)
Annoyingly, the vfds (IN-18s) only just showed up. If anyone wants a few I can send them to the next recipient of the junkbox.
Anyone want any steppers/controller ICs? i have some SLA7062M *3 here as well as one presoldered to pcb which sort of works on a good day (probably flaky track somewhere)
I also acquired a fairly sizeable pile of old Polaroid films dated 2007-8 including B/W
also have some 1.5V LDO regulators that got tagged onto an order in error.
any use?
Regards, -A
Sun Dec 27 2009, 02:12PM
Conundrum,
I'll try and post the box to you tomorrow.
Is the old Polaroid film the self developing kind? They used to have some great 3mm thick 6v batteries in them.
G.
Sun Dec 27 2009, 02:16PM
Yep. :)
i haven't tested one yet but 1 year out of date shouldnt be a problem.
EDIT:- might need a bigger box...
-A
Sun Dec 27 2009, 03:29PM
Hehe same problem I had when I got the box smile Is this one EU and UK or only UK?
Sun Dec 27 2009, 09:40PM
I'm not really that bothered if it goes onto the continent. It just means we will have two boxes in circulation - faster turn around if nothing else.
I'll leave it up to Conundrum. He can send it on to whomever he pleases.
I'll send out the tracking details once posted tomorrow Conundrum.
Can someone make this sticky? Or better still start a proper entry on the Wiki so we can track the contents and progress of both boxes? I'm still a newb, and would not want to screw anything up before i get to know everyone - after you know me i can then safely screw everything up! neutral
G.
Mon Dec 28 2009, 10:43AM
Box has now been posted. I have PM'd you the tracking number Conundrum.
May i suggest that Dalus gets it next?
G.
Mon Dec 28 2009, 11:53AM
yeah, someone else just pm'd me re. the box
ok to send it via the uk?
Bjørn
Mon Dec 28 2009, 01:01PM
Here is the wiki page: Link2
If you want to be on the list and they don't have access to the wiki just send me a PM and I will add you to the bottom of the list.
