  • Guests: 52
RF cycles vs spark
Fri Dec 25 2009, 08:33PM Print
How many RF cycles are needed to fully develop the spark output from a tesla coil? This applyes to all kinds of tesla coil (SGTC, SSTC, VTTC) or are there some differencies? I am interested especially for a VTTC. I remember that this was discussed somewhere in the forum, but can not locate the thread. Because a GMI90 stays ON under 3 microsec, I have to figure what would be the resonant frequency of the secondary.
Z28Fistergod
Sat Dec 26 2009, 04:03AM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
I think it would in part depend on how many cycles it takes for the primary current to build up. For my DRSSTC I don't see any improvement when increasing RF cycles past 8. I remember reading about someone else that had the same results, but I can't remember who.
By contrast Mr McConner's first DRSSTC took many cycles to build up it's primary current. Check the scope traces here:
The maximum possible current that could pass through a series resonant circuit for a given voltage depends on the ESR. The rate at which the current builds is proportional to the maximum possible current. So if we have two circuits with different ESRs, and our target current is less than the maximum current for each, then the circuit with the lower ESR will reach our target current first.
Also keep in mind that the current in the primary tends to build in a logarithmic or SQRT(X) shaped curve, so there is diminishing returns for every additional RF cycle. I would think the actual equation is something like the charging of a capacitor, maybe:
InstantaneousCurrent = MaxCurrent * (1 - (1 / e^ct))
where c is some constant and t is time
There is also some other stuff going on with the actual arcs but I won't claim to know much about that, something to do with RF propogation I think.
dex
Mon Dec 28 2009, 07:11PM
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
vasil wrote ...
For SGTCs I dunno.
But for VTTC HUNDREDS of RF cycles are needed to fully develop spark lenght.
How many cycles,depends on the operating frequency and max output voltage.
And for max spark lenght dependence on frequency and voltage for CW coils and VTTCs see graph here:
