  • Guests: 61
Marx Generator components sourcing
Sparkie
Fri Dec 25 2009, 03:43PM Print
Sparkie Registered Member #627 Joined: Thu Apr 05 2007, 04:05PM
Hello all amazed
I would like to build a marx generator that gives around 10cm discharges. I have a flyback circuit I would like to use as the power supply. I would reduce the input voltage to try and get around 5kv output. Its this one here: http://www.youtube.com/watch?v=JOTn7A4BFfs
With an input voltage of around 5kv, I'm thinking I will need some resistors capable of withstanding 5kv, and also capacitors.
Does anyone have some info on what 1M resistors would be suitable, and where I might be able to buy them in the UK?
Many thanks, John.
Myke
Fri Dec 25 2009, 05:52PM
People tend to use doorknob caps for Marx generators. You can use any cap that can withstand the input voltage. I don't think there is any special type of doorknob you need.
For resistors, you can just string together multiple 1-2W resistors. The total value of the string isn't too critical but a higher value would make the Marx fire at a lower rate. Some people have used inductors for charging the caps because it appears to be a low impedance to the DC but when it fires, the inductors look like a high impedance because of the fast rise time.
You could go for about 80kV with needle discharge points to get about a 10cm discharge (I think that's right).
Sparkie
Fri Dec 25 2009, 07:35PM
Thanks Myke. I am going to use 1000pf 6kV caps. Will try between 15 and 20.
How will the resistors hold up? I'm looking at 2W Carbon Film Voltage Rating:500V dc
May seem a silly question like putting 5kV through a 500v resistor but I cant see any 5kV resistors. Putting 10 in parallel seems a bit crazy and I haven't seen any designs like this. People just seem to use single 1M resistors. Perhaps with the low current it will be OK? I'm going to try using a Cockroft-Walton Voltage Multiplier like in an ioniser.
Thanks! John.
Fri Dec 25 2009, 08:22PM
If you mean 5kV RMS then your 6kV capacitors will fail toot sweet.
I am not at all sure what has prompted you to choose 1M, since the resulting pulse will have a very long time constant, which entirely defeats the point of using a Marx, but there are always plenty of suitable high voltage resistors on ebay, for example:
Sparkie
Fri Dec 25 2009, 10:19PM
All the designs I have seen use 1Mohm resistors. I will build it and see how it goes...
GluD
Fri Dec 25 2009, 11:23PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
My marx uses 1nf 15kv capacitors, and 1Mohm resistors ( I just use the 2 watt version)
Im feeding it with a flyback from a pc monitor.
Bought all the componets from RS.
With about 14 'stages' with those componets it makes a 14½cm discharge between steel balls or roughly 20cm point to point copper wire.
Myke
Sat Dec 26 2009, 12:18AM
The 1M resistors don't slow down the pulse because the capacitors discharge in series bypassing the resistors. You want the resistors to have a high enough impedance so they don't interfere with the amount of energy that is outputted.
People tend to ignore the 500V rating on resistors and just use 3-4 1-2W resistors in series. I've put over 2kVAC across a 1M 2W carbon comp resistor before and all it did was heat up (Was a bleeder resistor I forgot to take off the caps of a high voltage power supply).
Proud Mary, Marx generators are charged by a DC source so the supply shouldn't put out anything higher than 5kV. It's always a good idea to have extra headroom for safety reasons so caps with a breakdown voltage of >6kV should be fine.
Sat Dec 26 2009, 12:26AM
Sparkie wrote ...
Perhaps you might think of entering your data into VIG2003, rather than simply following the guesswork of others:
