  • Guests: 48
Help with an ignition coil?
3l3ctrici7y
Fri Dec 25 2009, 02:39AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
Here is a youtube video that is quite instructive.
HazzWold 1993
Thu Jan 07 2010, 04:35AM
Well i located the two input pins, submerged it under oil and ran the coil, it gave very high voltage output, heres the results
1262838908 2563 FT81257 Gedc0863
 Copy
radiotech
Thu Jan 07 2010, 06:12AM
If you use a relay oscillator, and have the battery in series with the coil and the contacts, use a capacitor across the contacts, like the kind found in the distributor of 'old' cars. they were about 0.4 uF.
and rated in high 100's of volts. Without that cap you got no spark,
so you walked. I once pinched the suppression cap off the alternator to get home.
quicksilver
Mon Jan 11 2010, 11:20PM
There are coils that are not legal for the street in the USA but for racing, especially drag racing that are very dangerously powerful. They have warning stickers all over them when you get them from junk yards, etc.
I have only seen one guy who had a working one and it put down 6cm of the thickest spark I've seen from a coil. This was NOT from mains but a 24 v supply!
You can find them on the web - under "non-street legal coils, Mallory". The specs are quite unique!
The guy used a 555 driver but it kept having problems.
Zeus
Mon Jan 18 2010, 01:34AM
Zeus Registered Member #2316 Joined: Tue Aug 25 2009, 03:04AM
I have got my relay oscillator working and I have had the best results with a 1.2 uF motor start cap.
About 40kv and with parallel antiphase coils 80kv.
