  • Guests: 53
Flashover problems
audio:deviant
Fri Dec 11 2009, 11:48PM Print
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
Hello all, very confused at the moment. Drsstc was running great and now I seem to be having flashovers all of a sudden, I moves the coil to another room and it's just started happening. I've raised it and still have the issue so I'm kind of out of ideas really and need some advice from you genius's
Sat Dec 12 2009, 07:08AM
The coils surroundings will change its resonant frequency, is it much different in the new room?
Higher to the ceiling, large objects closer to or further away now?
Have you tried moving it back, just to confirm that its not the location, but could be some of your electronics that was messed up, maybe some grounding that had a loose connection...
audio:deviant
Sat Dec 12 2009, 01:49PM
Right I have moved it back to the other room and all is well. I didn't think the room would make such a big difference. I have to do a demonstration on Monday how can I make sure this doesn't happen in this other room. When I moved it to the other room I changed the tappoint and lifted the seconday. Still had the problem tho. How can I cure this? Would a loose tap point to the primary cause this?
Cheers for the reply.
audio:deviant
Sun Dec 13 2009, 11:26PM
Right I've tried it in another room and it's happening again, any ideas of how I can prevent this?
brtaman
Mon Dec 14 2009, 12:09AM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Air humidity is another thing to consider, I remember having quite a few flashover problems with my SSTC, when the relative humidity of my lab jumped 20%.
Is there a significant difference, in humidity between the two rooms? As Mads already pointed out the coils surroundings can have an effect on the coils frequency, which could be a cause of your flashovers. Were you running the coil in close proximity to a wall in any of the two rooms? However, assuming you have the LC circuit tuned to slightly below resonant to account for the sparks, the change in the resonant frequency shouldn't be that great.
What are you using for primary? A form with wire wrapped around it, or copper tubing suspended in air?
teravolt
Mon Dec 14 2009, 03:34AM
pehaps it is being detuned by the length of the spark. what is lengh of its arcs? have you tried messing with the top load or its perjection point.
