  • Guests: 41
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
TL494 flyback driver
kiat
Mon Dec 07 2009, 03:42AM Print
kiat Registered Member #2115 Joined: Fri May 08 2009, 01:17PM
Hi everyone,
I have recently completed scopeboy's TL494 based flyback driver -- schematic here: Link2
for audio modulation: Link2
I have not connected the audio jack for audio modulation yet(read questions below), and i also have yet to connect the fullbridge as i still got to drill holes into a cpu heatsink and bolt them down.
Pictures also attached.
Parts description:
1)The big (short)potentiometer-dead time control (duty cycle)
2)the small (long)potentiometer-frequency control
3)two switches-one for audio modulation, the other for normal operation (actually I could have used a spdt switch - didn't think of that when i bought the switches)
4)The 2 small heatsinks hold the 2 R1560P2 fast-recovery power diodes. (D2, D5) The rest of the diodes i used UF5406.
5)Mosfets for the fullbridge - i used 4 pieces IRFZ46N mosfets.
Questions:
1)Not very sure, but what is the 2.2u 100v unpolarised capacitor for? (the one right next to the fbt in the schematic)
2)Also, if i add an unpolarised capacitor in parallel with the flyback primary coil, will there be an increase in performance? Maybe it must resonate with the flyback primary for a tank circuit with same Fres as the fullbridge output then good?
3)I also need to know, the pinout for a 3.5mm TRS connector for the audio modulation - which 2 pins (of the tip, ring and sleeve) are used, and which is the audio+ and audio com line?
4)Finally, what would be a "safe-ish" voltage to run the fullbridge at (IRFZ46N mosfets V(ds) only 55v),
5)and how much current would this circuit draw?(what is current draw determined by?)
Thanks,
kiat
1260156981 2115 FT0 Dsc03460
1260156981 2115 FT0 Dsc03461
