  • Guests: 51
Bosko (56)
hen918 (30)
Yuri_Ivanov (35)
SoldierOhm (37)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
off topic: 0.999 repeating Equals 1, proof inside!
Hon1nbo
Sun Dec 06 2009, 06:59PM Print
here is a proof that I find accurate, yet possibly irritating some people's understanding of math
given the number 0.999 repeating, (all decimals shown below are repeating FYI)
0.999 / 3 = 0.333 = 1/3
1/3 * 3 = 1
by transitive property, 1 = 0.999 repeating
any comments? - I personally think this is just ridiculous (even though it is technically true), because for example in a function that has an asymptote you can get infinitely close but never actually get there.
here is the wikipedia page devoted to the thought: wikipedia page
Edit 1: come to think of it, is there any sign of misuse of operations in this proof? such as in the classic example of using x=1 and derivatives to make 1=0?
EDIT: I decided to post another method after thoughts about legitimacy of using 1/3 in such a proof, again all numbers with a decimal place are repeating
let x = 0.999
10x = 9.999
10x - x = 9.999 -0.999
9x = 9
x = 1
Sun Dec 06 2009, 07:08PM
Are you saying that there's a difference between "infinitely close" and "there?"
If you look, the Wikipedia article for Zeno's paradoxes links the one for 0.999...
You might also enjoy reading Cantor's theories about "different kinds of infinity".
Z28Fistergod
Sun Dec 06 2009, 07:48PM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
DaJJHman wrote ...
1/3 * 3 = 1
I don't think that is right. 0.3 repeating is only an approximation of 1/3, so I don't think you can use that in your proof. For that to work you would need to prove that 0.3 repeating equals exactly 1/3. That is where we run into infinitesimal differences. For example, the limit of 1/x as x becomes infinite is 0, but the value of 1/x never actually equals zero, no matter what value of x we choose. The value of 1/x merely approaches 0. Where did you find this proof?
StevenCaton
Sun Dec 06 2009, 07:56PM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
I don't think that is right. 0.3 repeating is only an approximation of 1/3 so I don't think you can use that in your proof. Where did you find that?
It is not an approximation if it is *infinitely* long. They are the same thing
The first time I came across the proof I was somewhat baffled too.
I posted the "monty hall" problem a while back. It is another strange math brain teaser.
Z28Fistergod
Sun Dec 06 2009, 07:59PM
SteveC wrote ...
Well if you want to use that logic 0.9 repeating is infinitely long and is the same as 1, so the proof is superfluous.
I disagree with both and maintain that it is only an approximation.
Prove that 1/3 = 0.3 repeating and your other proof will be valid.
Otherwise I think it is wrong.
Hon1nbo
Sun Dec 06 2009, 08:25PM
Steve McConner wrote ...
I state this difference after the first few months of Calculus class in which limits were shoved into our heads and to never think of being infinitely close and there as the same thing
Z28Fistergod wrote ...
Otherwise I think that is wrong.
I guess this is possibly a problem, but similarly there are lots of problems in math that are just assumed true: for example, the only reason what the Triangle Congruences (Side Angle Side, Angle Side Side, Side Side Side, etc) can not all be proved without assuming one is true is because when proving the Pythagorean theorem you cannot assume that there are triangles in existence that are congruent to the triangle at hand unless you start with them and make the proof unusable in most cases, so they assume that one triangle congruency is true to prove the pythagorean theorem to prove the rest.
if the above were not the case them all of the triangle congruences could be proven with about a page each with no loops or paradoxes formed from using one to prove the other
in every proof, something must be assumed as true from either obviousness or logic otherwise nothing would be able to be proven.
Sun Dec 06 2009, 08:32PM
How about a numerical solution using decimal representation of real numbers?
For any x greater than zero, 0.999... + x will clearly be greater than 1.
Z28Fistergod
Sun Dec 06 2009, 08:50PM
DaJJHman wrote ...
...in every proof, something must be assumed as true from either obviousness or logic otherwise nothing would be able to be proven.
Ok, but like I said above, if we assume 0.3 repeating = 1/3 then we might as well assume that 0.9 repeating = 1. I don't see why either assumption is valid.
Hon1nbo
Sun Dec 06 2009, 10:22PM
I decided to put in the first post another method not involving fractions or any other infinite decimal besides 0.999 and what can be manipulated from it, and also I included the link to the wikipedia page
StevenCaton
Sun Dec 06 2009, 11:33PM
There shouldn't be any debate here about the fact that .9999 (repeating) equals 1. It is a well established fact of mathematics.
