  • Guests: 60
power factor correction
Crunchy Frog
Sun Dec 06 2009, 04:32PM Print
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
Is (or, when is) PFC necessary? I've seen one site that says it is, but I haven't seen it mentioned on most other sites.
Sun Dec 06 2009, 04:53PM
It's needed when you're using all of the amps available from your wall socket, but still want more power. Then PFC will cancel out some of the reactive current, giving you more watts for your amps.
Sun Dec 06 2009, 08:09PM
Unless we talk about switch mode PFC is almost only a demand from your electricity supplier.
We pay for the Current in phase with the voltage, but we load the distribution network with the reactive current as Steve mentions. So the suppliers are interested in selling their power at a minimal production cost, thus the requirements to keep a PF of at least 0.9 in industrial installations, in Europe there is no additional requirements for private homes, you can install all the huge motors you want without having PFC on them.
But when it comes to switch mode, lets say you build a switch mode power supply that is capable of delivering 10 kW of power, with a PF of 0.5 it will only be able to deliver 5 kW. So this is where PFC really gets interesting from your point of view.
