  • Guests: 28
Mercury metal price experiences?
1 2 3 4
Fri Dec 04 2009, 10:41PM Print
I need a pound or two of mercury to fill my McLeod gauge from ebay.
Seller will be shipping it empty because we confirmed that Hg is unmailable.
And that UPS and Fed Ex won't carry the metal, even in small quantities, without a lot of trouble and cost (e.g. hazmat registration number for shipper). I'm too old to be a party to "keeping one's mouth shut", and too busy and rich to be taken to task if contraband is discovered.
Found a local individual who has over 20 lbs of Hg, but wants someone to buy the whole lot. Whence the question of fair price. And I'll become perpetual custodian of whatever I can't resell locally.
As an industrial commodity the price is currently very low, around $3/lb (couple $100 per standard flask) due to usage restrictions, and a glut of hundreds of tons as Hg is phased out of chlor-alkali production plants. In fact European surplus is being routed through a Spanish mining company that agreed to suspend new production -- a price support policy to discourage overuse and waste, IMHO, at the cost of some cinnabar-mining jobs. frown
Scrap metal exchanges have liquid mercury lots (e.g. unused dental grade and used liquid Hg) offered at between $2 and $3 per lb.
But lab equipment exchanges still want over $50 per lb for technical grade mercury metal. And chemical supply houses want hundreds per lb for triple distilled reagent grade stuff.
What would you pay for 10 kg of mercury? Or 5 kg if I lived in your town?
Sat Dec 05 2009, 12:32AM
Twenty pounds? I don't think you want to hold onto 20 lbs of mercury at your home. I would try to get him to sell you less. I would first ask him what he wants per pound. I would pay $10/lb.
Sat Dec 05 2009, 07:37PM
My old physics prof (before he retired) gave me about a pound as a "because you are the weirdest guy I met who wont poison his family with it by accident" present. He said it cost him about 5$ when he got it from the school supply place.
Sat Dec 05 2009, 08:29PM
Delivery charges are the big killer, Rich, though of course they don't make your gums go blue before your teeth fall out.
And a McLeod gauge! How wonderful! smile
No real vacuum calibration is possible without one (that I know of) as the source of ultimate reference for your ion gauages etc.
(Yes, the environmental pollution around the abandoned cinnabar mines of Almadén will remain a hazard for many years to come. )
Might it be possible to make a McLeod guage that used some kind of near-room temperature alloy? Who can say?
A pragmatic approach might be to infer the degree of vacuum from the apparent MFP in a given gas.
plazmatron
Sun Dec 06 2009, 02:04AM
You could use diffusion pump fluid instead of mercury, as it has an exceedingly low vapour pressure, however you would need to recalibrate due to lack of density.
No one will fly Merury, since if there is a spillage, it will happily amalgamate with the Aluminium on the aircraft with interesting results smile
Les
MinorityCarrier
Sun Dec 06 2009, 05:05AM
If you ever find yourself going to Bend, Oregon, let me know and I'll arrange to give you a 5lb bottle of mercury.
Sun Dec 06 2009, 07:29AM
Thanks for the suggestions and offer. I ended up buying about half the lot, 9.3 lbs, for about $10/lb. It's more than I need, so I hope some can benefit other hobbyists and/or teachers around San Jose, California.
1260083792 2099 FT80612 Cr Hg
One curious thing, the "10 lb" bottle has a shrink-tubing seal but is only 3/4 full, and the contents look sort of dirty. Maybe when the McLeod gauge arrives I'll have to get some experience with cleaning the metal -- dilute nitric acid wash? Filtering through chamois? No distilling at my house, at least not of anything undrinkable. smile
Sun Dec 06 2009, 10:48AM
Klugesmith wrote ...
Hi Rich,
if Hg containers are filled to the top, it is not long before they burst when temperature rises. The 'dirtyness' is another issue.
mikeselectricstuff
Sun Dec 06 2009, 11:44AM
Out of curiosity, am I right in assuming that commercial disposal costs of mercury generally exceed its value? Is there a "break-even" quantity? - I imagine that much of the disposal cost is 1-off handling/admin type stuff that at some point would be offset by the material value.
Reason for asking is I occasionally get requests for info from people who found my Mercury Arc rectifier page asking about what to do with MARs they need to decommission.
Sun Dec 06 2009, 07:11PM
This is somewhat off topic, but in the US all cities have annual or bianual 'household hazardous waste roundups' designed specifically to keep people from chucking these kinds of things in the trash. They may give you a weird look if you bring in a gigantic mercury vapor rectifier, but as long as you don't have a truckload of them they should take it.
I assume there is a similar program in the UK, but I cannot say for sure.
