  • Guests: 43
01/13 si2030 (62)
OS1100A flickering trace then N/G any ideas?
Thu Dec 03 2009, 08:34PM Print
Hi all.
Turned on my previously working Gould OS1100A 'scope (old clunker but did work fine) and was greeted with a flickering trace. Adjusted a few things then... nothing :( GRRR
Any ideas? thinking maybe G1 or something similar failed..
-A
MinorityCarrier
Thu Dec 03 2009, 09:52PM
Do you have ~-1KV to -2KV on the CRT cathode? I'm assuming the anode is at ground.
Also check the first grid, (the blanking grid), if it is ~7 volts more negative than the cathode, that may kill the beam also.
Sat Dec 05 2009, 12:31AM
hmm... seems to be heat dependent.
if the scope heats up it slowly fixes itself (timebase returns, then traces)
Sat Dec 05 2009, 04:36AM
The easy solution the is to just go around with a can of cold (or a can of spray air turned upside down to give liquid) and start freezing components. I suspect is a capacitor that has dried out and become leaky.
Nicko
Sat Dec 05 2009, 06:14AM
Conundrum wrote ...
Does sound like a problem with the HVPSU, probably, as has been mentioned, a dried out electrolytic. I've recently fixed a Tek 7000-series scope with this problem and a Tek 2430A with the same problem but in the LVPSU side.
In your case, the presence of the trace initially means that I'd start on the HT side...
Statement of the bleedin' obvious: Be ever so careful...
Sat Dec 05 2009, 09:26AM
My job is repairing industrial electronics,
since we give a 1 year warranty on our work we ALWAYS replace ALL small electrolytics as a matter of procedure.
(yes they can be that unreliable, especially the small smd electrolytics).
This will usually fix about half of all faulty equipment !
The majority of other faults are man-made e.g. over-volting inputs.
With crt-based equipment I'd guess three quarters of the faults are cured by a cap change, so definitely I recommend that you replace ALL the electrolytic capacitors.
The sooner you do it the better as the leakage from electrolytics corrodes pcb tracks,
often leading to more serious faults.
Sat Dec 05 2009, 12:02PM
hmm. turned on today and it worked fine.
Its been pretty damp recently so that could be something to do with it.
FWIW I had it looked at about two years ago and the techie (qualified TV/video repairman) said he'd changed a few caps and resoldered everything in sight.
if it plays up again i'll change the caps, thanks for the advice.
-A
Sat Dec 05 2009, 06:21PM
Why not start by measuring all the voltages on the test points and comparing them with the figures in the manual? Anything else is just guessing.
