  • Guests: 48
Help
gixer
Tue Dec 01 2009, 09:38PM Print
gixer Registered Member #2493 Joined: Tue Dec 01 2009, 08:13PM
Hi
I am new to Tesla coil build and I have to come up with a design of a small coil which can be used indoors. Can anyone help me out?
Thanks
Mark:-(
Crunchy Frog
Wed Dec 02 2009, 01:02PM
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
There are a lot of good resources on the web if you look.
To start off with, Link2 has some good general design info, and Link2 is probably the most useful single resource, because you can test your design to see how well it works.
Dago
Wed Dec 02 2009, 09:15PM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
I'd also like to remind you of the rule (which you have naturally read, right?):
C. Do not ask for step-by-step instructions, detailed plans, or complete schematics. If anyone wants to make them available, they will. Try Google or the HvWiki.
gixer
Tue Dec 08 2009, 10:02AM
This there a minimum voltage that I need for a spark? Just I have been told a few different thinks.
##Thanks Mark
doctor electrons
Tue Dec 08 2009, 11:07PM
Google the dielectric of air. It will tell you how much voltage is needed to break 1" of air.
Whatever you do, make sure you are aware of all the safety precautions you need to take.
These devices are not toys; and high voltages are dangerous and potentially lethal.
Be safe and alert!
gixer
Thu Dec 10 2009, 09:59PM
Ok Thanks. I will look into it. I am building it for a college to use in experiments showing high voltages.
Thanks
Mark
cduma
Mon Dec 14 2009, 02:37AM
If you are unfamiliar with a man named Ohm and his famous law than you should probably(definetly) avoid anything over 50V.
BTW, people here may get upset with the lack of research you have done. You should ask more specific questions and only after you search google.
