  • Guests: 46
spark augmenter?
Crunchy Frog
Thu Nov 26 2009, 07:53PM Print
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
Would this thing actually work? Has anyone tried it?
6401
plazmatron
Thu Nov 26 2009, 08:00PM
That looks familiar. I think I saw something like that in Tesla's original notes.
What site did it some from? Are there experimental results?
Les
Thu Nov 26 2009, 08:53PM
Something similar here:
http://www.tesla-coil.com/ConcentricSpheres.htm
doctor electrons
Thu Nov 26 2009, 10:30PM
Very interesting! Do you have a link with more info on that setup?
I would be up for trying to make one!
Crunchy Frog
Fri Nov 27 2009, 03:54AM
It was on pupman.com with a bunch of unrelated stuff. No info on if it's been tried or not.
Dr. Slack
Fri Nov 27 2009, 08:51AM
As I understand it, the difference between what's shown, and simply a large topload with a wire between the two sections, is the variable conduction available between the two halves.
It asserts correctly that a spark between the two would happen much more quickly than streamer formation from the toroid. However, for this to be useful, it means the spark has to jump at the right time, after the streamer has hit a ground.
It seems that the choice of the resistor between the two halves could be critical. The value has to be low enough to charge the sphere with each half cycle of TC operation, so at 100s of kHz. However, it's got to be big enough to inhibit transfer of charge while streamer formation is taking place.
With DC high voltage terminal, say from a VDG or CW multiplier, there would be no difficult time constant problem. I don't see how it works with a TC, unless I have analysed it wrongly.
Mates
Fri Nov 27 2009, 10:54AM
Dr. Slack wrote ...
I see it the same way.
Do you have any guess for resitor value for a 160Khz coil (Mohms or Kohms) ? I can easily try this koncept ...
Herr Zapp
Fri Nov 27 2009, 07:29PM
Crunchy -
That's Ken Herrick's concept, which was discussed on the Tesla Coil mailing List some time ago. Ken's original schematic can be seen at:
Quickly reviewing the TCML archives, it sounds like Ken did build and test this concept, with positive results, and posted a photo on the old Hot-Streamer.com site.
However, I could not find the file in question (Link2 on the classictesla.com
"mirror" of the hot-streamer site; does anyone have a copy of this photo archived anywhere?
Regards,
Herr Zapp
plazmatron
Fri Nov 27 2009, 07:46PM
Herr Zapp wrote ...
Regards,
Herr Zapp
From archive.org smile
1259351103 1134 FT80235 Kch Tcg1
Les
Fri Nov 27 2009, 10:08PM
Aren't these extra spheres just various forms of lumped-constant L & C tuned circuit?
