  • Guests: 53
High Frequency NST
cduma
Thu Nov 26 2009, 06:22PM Print
I recently aquired a solid state NST thats rated for 5K5V 27mA and 29KHz. Would this be really good for a small 'Coil? Would the design process be the same as for a traditional SSTC? I think that this would be great for a portable unit for demos and such.
Coherent
Thu Nov 26 2009, 07:19PM
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
Honestly that would work pretty badly with a TC. It probably has GFI protection, will die easy in TC use and the high frequency ac would suck at charging the cap.
Thu Nov 26 2009, 07:36PM
Rectify it, it might work OK. But you won't get the resonant rise like with an iron core NST...
plazmatron
Thu Nov 26 2009, 07:46PM
Like with flyback driven coils, first rectify then smooth, and use a small rotary gap, in your TC primary circuit. I have had fair results with small flyback driven coils with rotary gaps.
Les
cduma
Fri Nov 27 2009, 03:05AM
Naw, if I have to go through all that than I guess I wont build one with it. I really wanted a light weight device and rotarys are not light...
raff
Fri Nov 27 2009, 10:01AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
plazmatron wrote ...
Les
THIS I would like to see... cheesey I WAS planning on making a small RSG for my flyback driven SGTC but was "carried away" when I was hooked up to SSTC...
Fri Nov 27 2009, 02:13PM
I would just rectify it, why smoothing it? Then you can use a static gap.
