  • Guests: 30
About High Voltage Insulating oils ....
Thu Nov 26 2009, 01:25AM
Yeah, Proud Mary , thanks for the PDF.
I will read it again, and make my decision soon.
-Patrick
Russell Haley
Thu Nov 26 2009, 11:04AM
Russell Haley Registered Member #2478 Joined: Mon Nov 23 2009, 03:24AM
I suggest good old fashioned bovine laxative grade mineral oil. However, if you can find a supplier, a product sold as transformer oil may be cheaper and will have more thorough specifications.
Fri Nov 27 2009, 05:37PM
Hey russell, I was thinking the samething Im going to a vet or Tractor Supply Company to see if I can snag some.
johnf
Wed Dec 09 2009, 07:58AM
Shell Dialla oe equiv
if you do not want to see a lot of expensive smoke
Bored Chemist
Wed Dec 09 2009, 06:36PM
Why talk about expensive smoke?
Cooking oil works fine at 20KV.
McCluskyCustom
Sat Dec 12 2009, 07:36AM
McCluskyCustom Registered Member #2538 Joined: Sat Dec 12 2009, 06:56AM
A good collection of info on HV oils by Tesla DIYers is found in the famous Pupman archives:
Thomas McGahee's Compilation
Transformer oils are high-quality, with all the impurities and water removed, and some have an oxidation inhibitor additive.
In looking into oils myself, I have found industrial high voltage oils difficult to obtain in low quantities. It seems Shell, Chevron, Castrol, etc. only make 55gallon drums, and no longer 5 gallon pails (called about 6 different oil distributors around California for xfmr oil). Some transformer oils series' I have found are:
Shell Diala
Esso Voltesso
Cooper Envirotemp FR3
Petro-Canada Luminol
Exxon Univolt
Good luck on the EE degree!
Carl Pugh
Sat Dec 12 2009, 07:14PM
Carl Pugh Registered Member #1064 Joined: Tue Oct 16 2007, 05:04PM
Coherent on Tuesday Nov 24, 2009 gave a source for Diala Oil AX.
5 gallon pail, $54.79+ I guess tax and shipping
McCluskyCustom
Sat Dec 12 2009, 07:49PM
Carl, could you post some contact information to "Coherent" where you can get the oil, please? Thanks.
Herr Zapp
Sat Dec 12 2009, 11:14PM
McClusky -
Just google "Shell Oil distributors" in your state. You will get the best pricing if you go directly to a large Shell lubricants distributor.
I'd recommend using the Diala AX instead of any vegetable oil. It's dead dry, free of any contaminants, has very low viscosity, and is well proven for high voltage insulation uses.
Regards,
Herr Zapp
Carl Pugh
Sun Dec 13 2009, 05:22PM
Coherent says can purchase Shell Diala AX transformer oil at Link2
