  • Guests: 57
Oscilloscope trouble
Goodchild
Sat Nov 21 2009, 05:23PM Print
Ok so for some time now I have been trying to scope 2 UCCs in push pull mode (full bridge) using the differential measurement method by using 2 channels on the scope and subtracting to get the voltage difference. But I seem to have a rather annoying problem 60Hz seems to be coupling back from mains into my scope some how and really messing with my readings. Is there a cure for this problem? I thought that maybe some thing as simple as an isolation transformer or line filter may fix the problem but have not tryed this yet.
Scope screen shots:
(This is supposed to me a square wave but the 60hz is modulating the square wave mistrust )
4121757633 Cea7275422 O
4121757657 886903dbb6 O
Sat Nov 21 2009, 05:46PM
What are your scope probes' ground clips connected to?
What is the negative supply rail of your UCC circuit connected to?
Goodchild
Sat Nov 21 2009, 05:51PM
The ground clips have been removed from the probes.
The negative supply rail is connected to a filtered and regulated 12v DC power supply
Bjørn
Sat Nov 21 2009, 05:52PM
First step is to double check your ground connection, and you need to connect the ground on both probes.
Edit: I tried dropping one of the ground connections on that kind of scope once and it caused all sorts of problems.
Goodchild
Sat Nov 21 2009, 05:58PM
So just attach the ground clips to the GND in the circuit?
I have seen people removing them and connecting them together also when testing in differential mode.
Edit: I tryed attaching the ground clips to the circuit GND and this fixed the problem cheesey
But what about larger bridges like in a DRSSTC or SSTC would you just attach the GND clips to the
negative power rail?
Coronafix
Sat Nov 21 2009, 09:53PM
Your negative supply must also be grounded, otherwise you will get the 60Hz signal through everything.
Sun Nov 22 2009, 02:02AM
Coronafix wrote ...
Well, if you have the ground leads from the scope connected to the negative supply, it is grounded. Scopes normally have the negative leads connected together, to mains ground.
But yea, you still need to earth ground the negative rail wink
Sun Nov 22 2009, 10:22AM
wrote ...
Whee, you took my hint.
wrote ...
Now it starts to get more complicated and dangerous, because the negative power rail is not anything like ground. Depending on your design, it might be -160V, -320V or whatever. Either way it would vaporize your ground clips.
What I've traditionally done is to run the SSTC off an isolation transformer, which allows the whole bridge to float. The negative power rail can then be grounded, and the scope probe clips safely hooked to it. My isolation transformer is only 500VA, so I would run my coils at reduced power for scoping purposes.
Another "solution" is to run the scope off batteries and allow it to float with the negative power rail, which is highly dangerous, because the casing and controls become live. If you want to operate the scope, you need to make completely sure that you're insulated from everything else in the surroundings, or electrocution is just a slip away. (Newer scopes with all plastic casings aren't nearly so lethal in this respect.)
Removing the ground wire from your scope's mains lead is even more dangerous: not only is the scope's casing live as before, but your coil's power rail voltage appears across the guts of the scope's power supply. If it breaks down, the scope could be completely destroyed.
Finally, note that while you saw the 60Hz interference on the A and B traces, it was cancelled out on the A-B.
Goodchild
Sun Nov 22 2009, 04:24PM
So just to clarify so that I don't go killing my self or my scope or my bridge, once the tesla coil is isolated from mains I can safely connect the ground clips to the negative power rail and the 2 probe tips to the 2 outputs of the bridge so that I can get a differential measurement.
Sun Nov 22 2009, 06:34PM
Yes, you got it.
