  • Guests: 35
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Induction Heater testing
James
Sun Mar 20 2011, 02:05AM
Experimentonomen wrote ...
The sound at the end was steam returning to the coolant tank, pressurizing it and blowing out the vents.
I'm yet to find a cheap crucible that will withstand 1500deg C.
Heres a new video after a few changes: Link2
Pick up some refractory cement and make one. I don't know if it's called the same thing where you are, but here they sell it at hardware stores for repairing fireplaces and stuff. I saw some that said it could withstand 1750C.
Experimentonomen
Sun Mar 20 2011, 09:34AM
problem is, thats only sold in like 50lbs bags or something like that.
Experimentonomen
Sun Mar 20 2011, 12:14PM
Update: Link2
Sun Mar 20 2011, 03:49PM
Go to Home Depot and buy furnace cement. It can withstand boiling metal. The problem is if you let the metal boil for too long you will melt the silica in the cement and get a metallic-glass mixture. However, for slightly lower temperatures, it is a good, cheap solution.
Inducktion
Sun Mar 20 2011, 05:16PM
Update: Link2
Whats your schematic? You said you used Imsosmooth's PLL one right? Could you possibly elaborate on what you mean by RC passive network? Or draw up a schematic? Thanks ^^
Experimentonomen
Sun Mar 20 2011, 06:07PM
Imsmooth, only one problem, i don't like in USA so i don't have home depot here, my best bet is a cheap used silica clay crucible on ebay.
Inducktion: imsmooth used a integrator circuit between the phase comparator part ad the VCO input of the CD4046 pll if, i use just a resistor and a capacitor.
James
Sun Mar 20 2011, 08:29PM
They sell it in small cans too, for making repairs. Look in the woodstove section.
