  • Guests: 40
Funnky GDT
Goodchild
Sat Nov 07 2009, 04:44AM Print
I recently built a 1:1:1 GDT and I scoped the output to see what the waveform looked like and I am getting some strange results. I'm driving the GDT with 12v and the scope reads 24V! that's average not including a little ripple. So my question is why am I getting 24v from a 1:1:1 GDT should it not be 12v? Also I did load one of the secondaries with a 470 ohm resistor this did not seem to change much. (also tryed 10ohm resistor, the resistor went up in smoke dead )
GDT specs:
1:1:1
24 awg
1 primary
2 secondaries
11 winds
electronic goldmine ferrite core
Driver Specs:
555 driving 2 UCCs in push pull mode running at about 38khz with 3uF DC block cap in series with GDT primary.
Scope shoots under no load:
4082301276 914756df7a
4082301298 02e6cbacc7 O
Z28Fistergod
Sat Nov 07 2009, 05:50AM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
That's completly normal.
When you configure the UCCs like you did you formed a full bridge. You should research what a full bridge is, and analyze the circuit to figure out just why it does that.
Goodchild
Sat Nov 07 2009, 06:37AM
:-? ah duuuu stupid me I should have seen that. Thank for pointing out my lack of look for the simple things!
Thanks again!
Sat Nov 07 2009, 08:47AM
Isn't the output more likely 24Vp-p or +-12V (with 50% duty cycle)?
I use 15V to supply my UCCs, also using 2 in fullbridge configuration and a 1:1:1 GDT, and I get +-15V on the gates.
Goodchild
Sun Nov 08 2009, 05:41PM
Dr. Kilovolt wrote ...
You are correct on this, I just was reading my scope wronge. It is producing 24Vpp or +-12v.
