  • Guests: 36
Suggestions for a microscope light
Sat Nov 07 2009, 12:06AM Print
Dennis Rogers Registered Member #1837 Joined: Tue Dec 02 2008, 02:20PM
Hey everyone,
I picked up an antique microscope some time ago and I've been meaning to build some kind of light source for it. I've seen LED rings made for this sort of thing but I was hoping for something of adjustable intensity. (At 10x magnification you don't need nearly as much light as at 93x) One option is an LED array where the bulbs light up in stages (1/3 of the LED's, 2/3's then all), the other is maybe a small incandescent or halogen with an adjustable pot. Anyone have suggestions for what would work best? Battery power would be nice but so would a dimmer type setup with infinite range. I have seen flashlights that seem to have brightness adjustable LED's, but I have to assume they are just controlling on/off times.
Dennis
Zum Beispiel
Sat Nov 07 2009, 12:57AM
LEDs can be PWMed. I used such a setup for my PWM light thingy Link2
Sat Nov 07 2009, 01:59AM
Hello Dennis, I have half a dozen classic microscopes (Zeiss, Vickers metallurgical &c) ) etc the which I have converted to LED use with excllent effect.
But the cautions and precautions are these -
1) You can't just wind up the DV volts and expect a corresponding linear output luminance of the diode. Your diode OP must be regulated in terms of pulse-width modulation.it easily easily provided by the famous 555 and a linear amp. If the diode in ON half the time, and OFF the rest of the time then you half the effective optical power granted to to wom, by all floes from this.
In genral, micrscope illumination is not so much a matter of point-source illumination, but of even illumination across the viewing field.
LED's are extemely brilliant and focused upon your conrea will punch a dead hole traigth throught it.
As you may know, lesbian- women--panties or not, are welcone in this site, so to keep matters short, I'll tell uou from personal experince that flows easy panning (level cheap by the norn) UHF radio - panties, and keep some prior copper's pants nearby. I never discuss these kind of social rembrance. Either you go on the walk, and are glad to be gay or trans, or what areyou ?
Plase don't you t feel you should or could have done better.
With my own eyes I saw you run back into the flames in attempts save others.
lots of love,
Stella XXX
Sat Nov 07 2009, 10:09AM
perhaps use the micro SMD diodes from dead phones. I once bought £50 worth of these just for the diodes and displays.
these are ridiculously bright for their size... :)
i did have an idea, get a 4017 or PIC,and switch the LEDs around a circle at high speed. Reduces current draw without affecting brightness, and if you also add a polarising filter on each diode at slightly different angles you can scan the sample at multiple polarisation angles.
-A
"Bother" said Pooh, as the warp core breached...
Sat Nov 07 2009, 05:29PM
I guess I'll go with a pwm led setup. Is there some sort of polarization filter I should use? I definitely don't want to burn a hole in my cornea!
Thanks for the replies, I'll update with my progress.
Dennis
