  • Guests: 63
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Minifocus x-ray tubes for sale
plazmatron
Fri Nov 06 2009, 10:16PM Print
They are modified beam tetrodes, that produce x-rays with an incredibly small focal spot.
I have a descrpition of them on my site HERE!
And they are offered for sale HERE!
Thanks!
Les
IntraWinding
Sat Nov 07 2009, 02:38AM
Nice. Have you managed to capture any shots showing the full resolution?
plazmatron
Sat Nov 07 2009, 05:02AM
Not so far. I will try it with my homemade fluoroscope on Monday, hopefully the camera will have no issues focusing on that!
I will upload a couple as soon as they are ready.
Sun Nov 08 2009, 11:09AM
That's pretty good for an HV rectifier! How did you make that neat lead shield?
btw, here's the link you had forgotten for Danyk's 6VS-1 x-ray experiments. Link2
plazmatron
Sun Nov 08 2009, 10:01PM
Uzzors wrote ...
Ah, thanks for the link! I knew I had seen it somewhere!
The lead shield is made from 3mm thick lead sheet, and is soldered along the join. Its amazing how a lick of black paint can tidy up a shield!
Les
plazmatron
Tue Nov 10 2009, 07:22PM
Best shot so far, of a 555 timer viewed using a fluoroscope.
1257880926 1134 FT79047 555
I am also selling unmodified 6VS-1's:
here
Les
EEYORE
Tue Nov 24 2009, 06:18PM
Hello,
I won one of these on ebay. While I wait for it to arrive, I am putting together the high voltage power supply. What would you reccommend more? High frequency flyback transformer based supply with rectification, or something such as a NST with voltage doubler (or tripler )?
Thanks,
Matt
plazmatron
Tue Nov 24 2009, 07:41PM
I recommend a small ZVS driven flyback, and tripler, rather than "big iron" for these. The machine can be made more portable this way, plus the current requirements are very modest, so an NST seems like a waste!
For heater transformers, I used 9v AC "wall wart" transformers, that I modified to 6.3V by removing some of the windings.
Thanks
Les
EEYORE
Tue Nov 24 2009, 08:47PM
Hello,
Good point about the NST, but going the ZVS route will no doubt cost much more money and be more fickle about running. On top of that, I hate messy looking proto boards when it comes to oscillators and power. smile(Which is what I would wind up with through protoboards) Unless someone knows of someone who makes ZVS pcbs, I might go the NST route and add a tripler+current limiting. (I dont plan to make this portable).
As for the heater, what current does it require? I have some 6.3VAC heater transformers around here somewhere capable of a few amps.
Matt
plazmatron
Tue Nov 24 2009, 10:41PM
The heater current is around 600mA or so.
Current limiting for a NST would be advised, since if the tube is allowed to overheat, the tube will happily draw whatever current is available, which would undoubtedly lead to the destruction of the tube.
I never use PCB`s for ZVS drivers, instead I solder the components directly to the MOSFET's.
This actually looks quite neat, since there are few components in the circuit. There are photos kicking about on the forum in places, where people have done the same.
Les
