  • Guests: 64
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
simple dc resonant tc design - opinions wanted
Crunchy Frog
Fri Nov 06 2009, 09:36PM Print
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
My goal was to make a dc resonant charged tc that was
1 cheap
2 won't trip my breakers (15A)
(btw i live in the US so keep in mind mains are 120vrms)
I decided to not smooth the dc due to the expense and danger of hv, large value caps. The voltage is a little uneven, but not too bad.
The primary cap is 2 microwave oven caps in series (448nF, 4300VAC) Due to this, the primary inductance is very low (~6.7 uH). The red line in the picture is at 4300V. Is that good? How much overvoltage can I get from a microwave cap?
Spark gap is rotary, max ~200BPS. All that stuff in the schematic with the relay is to simulate that.
Calculated max mains draw is 13.6A
Coil values are (from JAVATC):
Primary - 6" radius, 2" tall, 3.5T, 6.718uH, k=~.188 f=86.3kHz
Secondary - 4" radius, 30" tall, 1400T AWG24, 94.24mH, f=92.84kHz
detuning for streamers: 7%
Toroid 7" minor, 24" major (give or take)
Well? Should I build it like this?
1257543373 2422 FT0 Tc
