  • Guests: 63
RF/HV booty :)
Wed Nov 04 2009, 09:42PM Print
Hi all.
I just rescued this lot from being dumped. Is any of it any use?
mainly RF 2G modules, power supplies, FPGA backplanes, etc
1257370954 96 FT0 Pb041878
1257370954 96 FT0 Pb041880
1257370954 96 FT0 Pb041882
1257370954 96 FT0 Pb041883
1257370954 96 FT0 Pb041884
Wed Nov 04 2009, 10:15PM
Lots of fast hardware smile
Hazmatt_(The Underdog)
Thu Nov 05 2009, 04:57AM
And even if it doesn't work, you have hundreds of dollars in SMT components!
The high power SMT stuff is really expensive!
Thu Nov 05 2009, 12:06PM
What is it Conundrum, a cell phone base station?
GeordieBoy
Thu Nov 05 2009, 12:44PM
I think it is. I suspect those gold things in the first picture are Tx/Rx Microwave diplexers for the antennas.
Not sure if the RF power amplifiers are there, although the black things in the last picture seem to have VSWR warning lights on them.
I guess all the Sharcs are for the baseband processing.
-Richie,
Thu Nov 05 2009, 02:09PM
too bad sharc + JTAG = expensive :(
Thu Nov 05 2009, 04:13PM
Yes, to develop on your own SHARC board (as opposed to an ADI eval board) you need the full version of VisualDSP, which won't leave you much change out of $10k. Those are TigerSharcs, so they probably charge even more.
We have the full development environment and JTAG box for TI's C67xx 32-bit floating point DSPs. It cost a couple of grand too. frown
I think I spotted one of Xilinx's high-end Virtex FPGAs on there too (the big silver chip) so this board obviously isn't short of power.
Dave47
Thu Nov 05 2009, 05:37PM
Dave47 Registered Member #84 Joined: Thu Feb 09 2006, 01:06PM
The Vectron oscillator is probably pretty cool, too. I can't see the part number, but it looks like one of the super low phase noise types.
David
Dr. Slack
Thu Nov 05 2009, 07:05PM
It depends what you mean by low phase noise for the Vectron oscillator.
It's an OCXO (oven controlled XO), so it's likely to be the timing reference for the base-station. This will be super high stability, it's got to maintain +/- a gnat's if the external reference goes down, look up Stratum III for a typical holdover specification. However, it will not necessarily be supa dupa (just fairly good) at 20kHz or 10MHz offsets which would be needed for a quiet signal generator reference.
Anyhow, not to be sneezed at.
Fri Nov 06 2009, 12:06AM
cool. anyone interested in the boards?
i took one of the receivers apart, 140 screws later and i have some MMICs, random logic etc and what appear to be microwave mixer diodes.
have three more of these fpga boards and another TCXO board.
-A
