  • Guests: 47
Ugly gate waveform, what to do?
mmt
Tue Nov 03 2009, 08:01PM Print
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
Hi all.
I am currently working on medium sized drsstc with steve's OCD driver, closely this one Link2 A driver seems runs great, even everithing worked on first time . But I have a bad feeling about this Gate waveform Link2 as u can see there are a ringing spikes on max and min voltage. I dont know what this ringing may cause, any ides? I notices the ringing rise with rising voltage on bridge as u can see there is no ringing on 9V on bridge and awful looking one on 36V. I dont know if this is a commnon problem, but can it be some misunderstanding in my old tesla oscilloscope if it is displays somkinda wrong? I dont have a explanation for this. I have done some reading here Link2 but nothing helped. Anyway i thing its a wery usefull stuff!
Here are some my specifications:
GDT winding: 8:16:16:16:16
10ohm and paralel schottky diode on every Gate
15V zeners on GS
GDT cap 1uF MKT
transistors HGTG30N60B3D
(oscillosope Tesla BM550) mistrust
Any more informations u need just write here and I will responde.
Thanks,
Martin
Linas
Tue Nov 03 2009, 08:28PM
put larger Rgate
and also, you can calculate diference between Tdon and Tdoff, and use another resisitor in series to gate diode.
so if you have 10Ron, and 20ns tdon and 200ns tdoff use 1R+1N5819.
GeordieBoy
Tue Nov 03 2009, 08:29PM
If the ringing isn't present when the DC bus voltage to the H-bridge is zero, and it gets worse as you increase the DC bus voltage.... Then, i'd hazard a guess that it is one of the following:
1. Forced reverse recovery of the free-wheel diodes when each MOSFET turns on. What devices are you using for the switches and what devices for the free-wheel diodes?
2. Shoot-through (cross conduction) between the MOSFETs if the turn-on is set faster than turn-off.
...or maybe even...
3. Ringing of the stray inductance in the supply wiring (diode's clamping loop) if the bridge layout is sloppy.
What was the load you had connected to the bridge during the test?
Have you included some dead-time on the drive waveforms?
What decoupling capacitance do you have across the DC bus supply right at the H-bridge?
The schottky diodes should be pointing away from the MOSFET gates with a resistor in parallel with them. You could try increasing this resistor to slow down device turn-on and see if it improves the ringing situation.
-Richie,
mmt
Tue Nov 03 2009, 09:05PM
Hi Richie,
I am using a HGTG30N60B3D Link2 IGBT's in full bridge and free-wheel diodes are just those internal. I am running whole coil during test as this is a feedback driver system. My oscilloscope has a 27pF input, is this a dead-time parameter?, if not what is? I have a 5uF decoupling capacitance on bridge.
I have right way connected diode on resistor, just need to increase the resistance.
mmt
Thu Nov 05 2009, 09:40PM
I have just tested gates with rg 1,2ohm, 25ohm and without resistor and all of these waveforms looked same as 10ohm+skotky.
so, ...any ideas? rolleyes
